Echo Leaf Blower And Vacuum Starting Problem - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-27-2016, 04:25 PM   #1
Rewards Points: 108
Echo leaf blower and vacuum starting problem
Suddenly my trusty Echo leaf blower failed me after many, many years of dependable service.
1: cleaned the carburetor added new gasket kit.nope?
2: checked the fuel lines looked good air cleaner clear ?
3: checked the spark arrester it's clear ?
4: changed the gas/ oil this was good too ?
5: checked the door safety latch to the shredder intake this was tight ?
6: changed the spark plug and checked the spark this was ok too
ok I ordered an new carburetor and fuel line 3 piece kit
after installing these ( still not running )
Now this had to be something easy so I begin my process all over again
I put a piece of tape on the shredder door safety switch closed the door tighten down the knob pulled the cord and brrummmm it started right up.
so I guess the door switch was worn just enough to stop the blower from starting
well 15 to 20 years on this Echo I put is about $45.00 But it's the best out there
I hope this helps someone someday
I love this forum
Robert75
robert75 is offline   Reply With Quote
Old 04-27-2016, 06:38 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: Echo leaf blower and vacuum starting problem
I moved this to 'tractors and mowers' that's as close to 'small engine repair' as we have--Moderator
Old 04-27-2016, 06:40 PM   #3
Retired Moderator
Thanks for the trouble shooting tip---
Canarywood1 (04-27-2016)
Old 04-30-2016, 08:18 AM   #4
Rewards Points: 108
I repaired the safety switch
so that the blower shuts down when shredder door is loose or opened
Safety First
Robert75
The Following User Says Thank You to robert75 For This Useful Post:
oh'mike (04-30-2016)
Leaf vacuum mj12 Tools 8 03-31-2015 09:09 AM
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
