Echo Chain Misiting Oil! - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-03-2014, 05:31 PM   #1
Bluwolf's Avatar
Rewards Points: 87
Smile
Is My Echo Chainaw Chain Getting To Much Oil?
This is an old Echo CS 346 that I inherited. When I first got it started, The chain wasn't getting oil. I took off the bar/chain and cleaned the oil path. Now it flings a heavy oil mist. I checked the oiler adjustment and it's almost at minimum. I'm not very familiar with chainsaws so not sure if this is normal, don't think so. I can't find any information about too much oil and I'm temped to turn the adjustment to minimum. What's the consensus on this. Turn it all the way down and just make sure it's getting some oil? Thanks, I appreciate anyone with a little experience to chime in here! I'm Truly Amazed that this Echo started with only some extra pull's and a new primer bulb after 9+ years. With fresh fuel, of course! (I'm a STIHL Guy) Maybe I should evaluate this and in 25 years or so, when my STIHL Trimmer wears out , think about getting an Echo!
Bluwolf is offline   Reply With Quote
Old 08-03-2014, 05:56 PM   #2
Oso954's Avatar
Rewards Points: 1,952
Throwing some bar oil when not cutting is normal for Echos.
Here are some instructions on adjusting the oiler.
http://homeguides.sfgate.com/adjust-...aw-100482.html
You might want to run the newspaper test and then make a judgement about cutting it back.
When you are cutting wood, most of the mist will disappear into the wood or sawdust.
Oso954 is online now   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
Bluwolf (08-03-2014), gregzoll (08-04-2014)
Old 08-03-2014, 06:05 PM   #3
Bluwolf's Avatar
Rewards Points: 87
Thumbs up
Thanks Oso954! That just showed me how important it is to keep that oil path clear on the bar. I'll try the newspaper test. Thanks Again!
Old 08-03-2014, 06:10 PM   #4
Bluwolf's Avatar
Rewards Points: 87
What Brand of Chainsaw do you use? STIHL, Right?
Old 08-04-2014, 02:56 PM   #5
Oso954's Avatar
No, Husqvarna for big jobs. Craftsman electric for small stuff around the house.
oiling chain saw Startingover Tools 20 09-26-2013 05:55 AM
Garage door chain hopped off--how to fix (w/o adjustable slack)? EricBNeverScare Windows and Doors 5 07-10-2013 09:20 AM
Staining around chain line wires. mae-ling Painting 6 07-12-2012 09:29 PM
Flusher chain problems debd Plumbing 2 06-30-2011 02:05 PM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
