Deere Lawn Tractor Fuel Pump Bad? - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-07-2019, 03:21 PM   #1
Rewards Points: 141
Deere lawn tractor fuel pump bad?
Hi...
I just went out to start my L118 Deere lawn tractor and it wont start. Replaced the fuel pump and still no go. Pulled the line off the outlet of the fuel to see if there is gas coming out and nothing is coming out.
I am planning to replace the fuel pump but is there anything else I should check ahead of that?
whoppr is offline   Reply With Quote
Old 04-07-2019, 03:28 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 264
Re: Deere lawn tractor fuel pump bad?
Ayuh,..... Everything, Up-stream to the tank, 'n the tank itself,....
Old 04-07-2019, 03:30 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 1,350
Sure. Check the fuel filter, especially if you use methanol laden gasoline. Also, does it actually have a fuel pump or is it gravity fed? Just curious.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-07-2019, 03:41 PM   #4
Rewards Points: 141
I actually replaced the filter already....Figured that was easy and cheap. Pretty sure its a fuel pump... Looks like this and the engine is a Briggs Intek 20
https://www.amazon.com/Briggs-Stratt...-garden&sr=1-5
Old 04-07-2019, 04:41 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 228
That is an impulse fuel pump, common on small engines. Are you sure you hooked up the 3 tubes correctly? Prime the pump and spray some gas in carburator with air filter removed. Now start engine.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 04-07-2019, 05:10 PM   #6
Rewards Points: 141
I have not even tried replacing the pump yet. I have not bought it yet. My first step was replacing the fuel filter and that did not work. Figured I would ask here on the forum first before ordering a new pump or stopping at the mower shop.
Its a good suggestion... let me try getting some gas in the carb as you suggested. I only tried removing the line from the outlet of the pump and tried to see if I could get gas to pump out into a can. Did not work....I am not sure how best to get to the carb. I seel the fuel line go under the housing for the air filter. I will have to check again and see if its more obvious.
I also loosened the gas cap in case it no air was flowing into the tank and there was a vacuum.
Thank you
Old 04-07-2019, 08:02 PM   #7
Usually Confused
lenaitch's Avatar
Rewards Points: 1,008
I don't know all of the JD model lines but does your carburetor bowl have an electrical wire connected to it? That is a fuel shut off solenoid and can foul. Also, I'm kinda surprised a JD engine would use a B&S pump but, again, not familiar with all of their lines.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 04-08-2019, 07:05 PM   #8
Rewards Points: 141
Hmm...Not sure.... I think I recall a solenoid being called out on a parts list. I would need to check. I know its a B&S engine. Its not a high end Deere, just the lawn tractor, a step up from the L110 and its about 14 years old. Engine is B&S Intek 20
Old 04-08-2019, 09:14 PM   #9
Usually Confused
lenaitch's Avatar
According to the Interweb, it does have a carb solenoid, but if you're not getting fuel it's not likely the problem. If there is gravity flow from the line out of the tank, it is likely that either the pump is pooched or it's not getting vacuum to operate it. Maybe check for an intact vacuum line to the pump.
Sic Itur ad Astra
Old 04-16-2019, 05:46 PM   #10
Rewards Points: 141
So... figured I would try again... outlet pumped gas into a can when I tried to start it. Hooked up fuel line again and it started right up.
Couple questions.
How do I check this solenoid and where is it and how does it work? Does it turn on the fuel pump? Or is it in line with the fuel and opens and closes?
Also the pump if the vac line had a hole, how do I check that? It goes down to the OHV.
My guess is still that the fuel pump is flakey, but could use some insight how to eliminate the solenoid and other items.
Old 04-16-2019, 09:20 PM   #11
Usually Confused
lenaitch's Avatar
The Interweb offers a few links - there are probably others.
The carb solenoid is a fuel shut-off:
Other than a visual check of the vacuum line, try this:
Sic Itur ad Astra
Can't drain electric water heater dubina Plumbing 35 08-02-2017 09:07 PM
Sump pump check valve, on pump or spliced in pipe? ponch37300 Plumbing 1 06-18-2016 01:26 PM
Heat Pump Thermostat Replacement BuckeyeAaron HVAC 81 02-01-2016 05:00 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
