Cub Cadet LT1052 - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree3Likes
  • 1 Post By de-nagorg
  • 2 Post By joecaption
Old 11-09-2018, 09:23 AM   #1
Rewards Points: 72
Cub Cadet LT1052
I mowed yesterday and when i went to start my mower back up, the engine wouldn't turn over. It looks like the flywheel is not moving and it's making a weird sound, almost like a ringing, but not cranking.
Any ideas what this could be?
pats12 is offline   Reply With Quote
Old 11-09-2018, 10:14 AM   #2
Guapo
Rewards Points: 11,950
Re: Cub Cadet LT1052
Is there a flywheel inspection cover that you can remove?
Guap0_ is offline   Reply With Quote
Old 11-09-2018, 10:25 AM   #3
JUSTA MEMBER
Rewards Points: 428
Electric start?
Battery dead?
Battery post corrosion?
Try to move the flywheel by hand, if not moving = locked up.
Really need more data.
ED
de-nagorg is offline   Reply With Quote
Old 11-09-2018, 01:52 PM   #4
Rewards Points: 72
so it looks like some of the gears on the flywheel ring are broken. I put a new starter in and it starts up much smoother, but is it ok to continue to use it with the broken flywheel ring gears broken off? I would think it's ok but wanted to check.
Old 11-09-2018, 04:22 PM   #5
JUSTA MEMBER
Rewards Points: 428
Yes you can operate it with some of the starter ring teeth missing.
But eventually it will wear the starter Bendix teeth off.
And will eventually stop right at that spot, and the Bendix will have no teeth to start with, and you will need to turn the engine to where the Bendix will engage the starter ring to crank the engine .
Many old cars do this, and until the owner gets tired of replacing starters or repairing them, they finally get a new flywheel starter ring assembly.
ED
Msradell likes this.
Old 11-09-2018, 04:34 PM   #6
Rewards Points: 18,118
Something looks really wrong to me in that picture, besides the missing teeth.
Looks like the rings no longer even attached to the flywheel to me.
Msradell and de-nagorg like this.
Old 11-09-2018, 08:36 PM   #7
Guapo
If it doesn't start, spin the engine by hand until the teeth align with the Bendix drive. Sooner or later, you will have to replace the flywheel & the starter or the drive.
Old 11-09-2018, 10:39 PM   #8
Msradell's Avatar
Rewards Points: 912
I also noticed that, at least it looked very strange.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Cub Cadet Riding Mower Help Coffeebuild Off Topic 5 05-01-2018 08:39 PM
cadet electric baseboard johnnyquest1426 Electrical 9 01-03-2017 07:20 AM
replacing cadet heater under recall (model # TW2422) mishyq Electrical 5 12-04-2014 11:15 AM
240 Cadet heater plug question 4k watt sharky74 Electrical 2 11-18-2012 10:41 PM
Disabling CADET Wall Heater? timberwood HVAC 3 10-21-2012 12:28 AM
