Cub Cadet LT1050 Won't Start - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 11-06-2015, 03:25 PM   #1
Rewards Points: 68
Cub Cadet LT1050 won't start
I was mowing up leaves today for about 45 minutes. When I went to empty my clippings I couldn't get my mower (CC LT1050 about 8 years old with 25 hours) to start back up. A couple weeks ago I changed the spark plugs, gas filter, and added fuel stabilizer to my fuel but have used the mower once before today with no problems. II tried charging the battery today, changed the air filter put still nothing. The engine cranks, but doesn't turn over. I used my inline spark tester and am getting spark.
Don't think it's a fuel problem since I was just using it 5 minutes before.
Anyone have any ideas on what else I can try??
pats12 is offline   Reply With Quote
Old 11-06-2015, 04:29 PM   #2
griz's Avatar
Rewards Points: 572
You need to verify it is getting fuel.
griz is offline   Reply With Quote
Old 11-06-2015, 04:48 PM   #3
Rewards Points: 68
How do I do that??
Old 11-06-2015, 06:22 PM   #4
ZTMAN's Avatar
Rewards Points: 338
Did you check the kill switch under the seat. Sometimes they come loose and will prevent you from starting the mower.
Also did you disengage the blades when you shut the mower off?
If you want to see if it is the fuel, spray some starter fluid in the carb. If it starts with that, you know you have a fuel problem.
ZTMAN is offline   Reply With Quote
replacing cadet heater under recall (model # TW2422) mishyq Electrical 5 12-04-2014 10:15 AM
compressor wants to start but won't wetbar HVAC 13 06-17-2010 06:15 PM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Tools 2 08-26-2009 08:26 AM
Troy-Bilt 2-Cycle Gas Trimmer Will Not Start g8tkeeper Landscaping & Lawn Care 3 08-13-2009 10:58 AM
How to repair/clean centrifugal start switch pointertopica Electrical 4 12-03-2008 07:05 PM
