Craftsman Mowing Deck Disintegrating! - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-18-2015, 12:08 PM   #1
Rewards Points: 214
Craftsman mowing deck disintegrating!
I bought a craftsman 46" riding mower off craigslist early last year. Worked great for the whole season, but I did notice the front of the deck had some serious rust going on (large gaping hole near one of the arms) which had gotten bigger since I bought it.
I was just outside with it and it seems half way through my backyard, the part that was rusting broke off, taking one of the arms with it! The deck is being held up right now by only one side, which can't be good (I can't really raise or lower it much, only one side moves), and it looks like it may have hit one of my tires when it fell off (tire is hanging off the rim).
This is my first riding mower I've ever owned, so I'm not sure how much repairs should cost. Is replacing the deck expensive? Can you even buy just the deck somewhere?
dishe is offline   Reply With Quote
Old 06-18-2015, 12:34 PM   #2
Rewards Points: 17,912
Just one of the many draw backs of buying an older used mower.
Not likly worth replacing with a new deck.
No one can see it without a picture so hard to even guess at how to fix it.
Old 06-18-2015, 12:56 PM   #3
ZTMAN's Avatar
Rewards Points: 338
If the mower is in otherwise good condition, you should be able to find a used deck. Most mower repair shops have them. Easiest way to find is on craigslist. Should cost around 100-200 dollars
ZTMAN is offline   Reply With Quote
Old 06-18-2015, 01:12 PM   #4
Retired Moderator
Rewards Points: 7,174
Craftsman were made by MTD---start looking on Craigs list for someone selling a junk tractor with your matching deck----I saw a small mountain of dead tractors at the metal scrap yard yesterday---
Another option might be to have a bit of steel welded onto the old deck---
Old 06-19-2015, 01:03 AM   #5
John
JD367's Avatar
Rewards Points: 206
If the deck is that far gone,repair would be useless .
Not all Craftsman lawn tractors were made by MTD,...some were made by Murray/AYP.
If you need a replacement,you'll need the model and serial numbers from the tractor(usually found on a label,under the seat).
Go to: [url]WWW.searspartsdirect ,and enter the model number,and select the deck size.
Deck shells are still available,for some models,but,if not,you can check Craigslist,or ebay. NOTE:even getting a new shell,the bolts that hold the mandrel assemblies to the deck are noted for breaking off ! If that happens,you'll have to buy new mandrel housings,or assemblies.
A GOOD used deck will cost from $50,to $150,depending on your area.
JD367 is offline   Reply With Quote
Old 06-19-2015, 04:51 PM   #6
Rewards Points: 214
Here are some pictures to help illustrate what happened:
I clearly need to clean off the clippings that gathered around the belts, too. I guess that's what happens when there is a hole for them all to escape from while mowing!
Here's a shot of the part that fell off, which I recovered from the lawn:
And this happened at the same time- I am unsure if they are related or not, as it didnt fall underneath that tire or anything like that.
For the record, I mowed the rest of the back yard just fine before realizing what happened. I did notice a bit of a line in the ground where I turned, but it wasn't until I made it back to the garage that I noticed the tire. The grass clippings are a mess around the deck, and I can't raise the deck much. And avove all else, the tire being off the rim is going to keep me from doing it again until this is fixed.
Old 06-20-2015, 05:31 AM   #7
Retired Moderator
Old machine----You need a new tire or an innertube---and a new deck---
Old 06-20-2015, 11:07 PM   #8
Msradell's Avatar
Rewards Points: 818
Replacing the entire mower would probably be a better option.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following 4 Users Say Thank You to Msradell For This Useful Post:
gregzoll (06-21-2015), joecaption (09-17-2015), NickTheGreat (09-18-2015), oh'mike (06-21-2015)
Old 06-23-2015, 11:49 AM   #9
Rewards Points: 214
Well that's a darned disappointing attitude to have, you guys. No offense, but I expected more from a website for DIYers.
For starters, I don't have a lot of money. Buying a new one was never something I was remotely interested in doing. I bought this one used last year (I believe its a 2004 model), because I was tired of pushing around a mower and it was almost the same price as a mowing service for the year. Aside from the rust on the deck, the thing is in beautiful running condition, especially for the age and the price I paid. Obviously, I bought it expecting things to come up that need to be repaired/replaced. I have a couple of neighbors on the block who are using older ones in worse condition, and I figured instead of bothering them I could ask the collective power of the DIY chatroom for tips on keeping this thing running.
I never dreamed that the response would be to give up on it and buy a new one! Dissapointing, indeed.
Old 06-23-2015, 11:58 AM   #10
Rewards Points: 214
Meanwhile, as far as the tire goes, it doesn't appear to be punctured at all. It happened when I was on a heavy slant to one side, so it probably put too much pressure and popped the rim out. I'd guess that tire needed some air to begin with, and the combination of low pressure and weight leaning towards the left on a hill caused it. Now that I've looked over the damage, my theory is that's what caused the deck to suddenly hit the ground (since without the tire's pressure the whole thing dropped on one side) and break off that part of the deck's shell. The rest of the deck does still work fine, it continued mowing until I came around and put it away. I just can't raise it on that side anymore.
So, a little bit of youtube research has shown me that this sort of thing happens to the rimless tires pretty often, and they have some pretty interesting ways to remount it on their own (some of which involve using lighter fluid and a match- which doesn't really sound safe to me!). One of my neighbors says he uses a high pressure air compressor and has managed to hold the tire in place and quickly fill it to pop on. Either way, I don't necessarily need a new one OR a new mower!
A new deck is on my radar, though.
Old 06-23-2015, 01:07 PM   #11
Rewards Points: 1,502
The deck hitting the ground may be what prevented the tractor from rolling on the heavy slant and resulting in severe injuries.
For a quick fix tie the limping deck side up with a tarp strap and take the wheel off and transport to a tire shop to be inflated or if you have compressed air, a schrader valve removal tool and know how to strap squeeze the tire you may be able to inflate the tire yourself.
Old 08-04-2015, 07:22 AM   #12
I have used a belt already to wrap around the middle of the tire to help put pressure all around the tire to help it bead when filling
Travis123f is offline   Reply With Quote
Old 08-04-2015, 07:57 AM   #13
The OP seems to be pissed and gone, but do you see something strange about pics #1,#2 and then #3. #3 doesn't fit too well in the scheme of things being #3 looks as if the tractor was well maintained. In my opinion the purchaser, admitting he knows very little about lawn tractors, was craig's list scammed. That deck isn't original to that tractor.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
oh'mike (08-04-2015)
Old 09-17-2015, 07:37 PM   #14
Rewards Points: 214
Hey, no, I'm still around, just been busy.
I did successfully get the tire off and used my neighbor's industrial-sized air compressor to bead the tire (while using a ratchet strap to help hold it so it will seat). Then I put it back without the axle key and had a bugger of a time trying to figure out why it wouldn't move- I started another thread about that problem, and you even commented in it:
http://www.diychatroom.com/f106/craf...-brake-290217/
Anyway, its all working just fine now. Yes, the deck does appear to be rusting more than it should be compared to the rest of the machine, but it is still working. In fact, I went to take it out today but I misplaced the keys. If I recall correctly, these keys are all standard and not unique to the mower, so I'll probably go back to that neighbor and borrow his spare.
The Following User Says Thank You to dishe For This Useful Post:
oh'mike (09-18-2015)
Old 09-18-2015, 08:12 AM   #15
dd57chevy's Avatar
Rewards Points: 2,718
Dishe , we're trying to help . Lot of knowledgeable men on this site .
The thing I would point out is there ARE lawn & garden tractor junkyards . I have actually bought parts from a John Deere junk yard in your state . If you can't find anything on C/L or even E-Bay locally look to see if there is a generic tractor j-yard close .
dd57chevy is offline   Reply With Quote
Rooftop deck change: why is there a leak now? stripedbass Carpentry 0 02-24-2015 03:32 PM
Pool Deck Cantilever nooneisathome Building & Construction 2 09-20-2014 09:13 PM
Deck Stain? pomlady7 Painting 13 05-24-2014 04:58 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 12:10 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
