Craftsman Leaf Blower Takes Forever To Get Fuel - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-25-2015, 09:37 AM   #1
Rewards Points: 229
Craftsman leaf blower takes forever to get fuel
I have a Craftsman leaf blower that is about 5/6 years old. Two years ago I had to get a new carb for it. The mixture screws are sealed, does need adjusting, I will get it done sometime. The main problem now is that it takes forever to get fuel to it. The primer bulb is doing its job. This started last year and has gotten worse. I can pull on it forever and it does not get fuel to the plug. I hook my electric drill to it/ switch it to start and crank for about 30 seconds before it will fire. Then it runs fine. After shutting off it will start by pulling but after about an hour I have to get the drill out again. Any ideas? Thanks.
thunderhead is offline   Reply With Quote
Old 08-25-2015, 09:44 AM   #2
ZTMAN's Avatar
Rewards Points: 338
I would replace the gas line and put sea foam in the carb to see if that cleans it out. I would also change the spark plug and clean the air filter
ZTMAN is offline   Reply With Quote
Strange oil furnace problem: blower comes on before burner robparrott HVAC 6 12-12-2011 01:55 PM
Takes forever to get hot water Cahriad Plumbing 5 11-30-2011 06:59 PM
Furnace takes forever to heat house kkollins HVAC 15 11-18-2011 10:05 AM
GE Profile gas oven takes forever to preheat gwrross Appliances 2 06-28-2009 01:57 PM
Toilet Tank Takes Forever To Fill xamplesample Electrical 2 01-19-2009 12:08 PM
