Coil Replcement On JD/Kohler 12.5s Oldie - Tractors & Mowers - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 04-11-2015, 10:49 AM   #31
Rewards Points: 706
Good to hear that, JD! My buddy probably can wrap his head around this stuff without dumbing it down for me. I'm just a go between for now. Thanks again for breaking it down tho. Easier for me to relay to him by phone.
onjtrainee is offline   Reply With Quote
Old 04-11-2015, 11:22 AM   #32
Rough Rooster's Avatar
Rewards Points: 414
Not giving up,my friend.
Just didn't want too much technical info to confuse things.
RR, no Kohler I've ever seen( I'm 63 yrs old) had the ignition coil under the flywheel.
The STATOR coils, yes,but these are for charging and lighting,not ignition.
Older Kohler engines used an auto motive type ignition coil that mounted in a bracket on the side of the engine. 12v dc went to the - terminal of the coil,and a wire from the + terminal ran to the points.
Have a JD 112 with Kohler engine in my yard right now that came stock with ignition coil under flywheel along with charging coils. When its ignition coil died the previous owner opted to use automotive coil mounted outside. It works very well.
May I refer you to http://www.jackssmallengines.com/Jac...ine/20741/6882 ?
Look at what is bracketed in picture #9.
(BTW I am 70. Been around a long time. Also ASE certified Master Auto Tech with many years experience. Still willing to learn.
My apologies to OP for getting in crossfire. I just hate to see "misinformation" posted on forums.)
RR
Now I will go fix a TroyBilt steering malfunction.
Rough Rooster is offline   Reply With Quote
The Following User Says Thank You to Rough Rooster For This Useful Post:
JD367 (04-11-2015)
Old 04-11-2015, 01:32 PM   #33
John
JD367's Avatar
Rewards Points: 206
Well,RR, I stand corrected,and you have my apologies !
I have ,as I said,never seen this type of ignition ,on a Kohler engine !
All the one s that came through my shop ,were the external coil style ,from the factory .
So, I learned something,didn't I ?
No hard feelings on my part,I assure you.
JD367 is offline   Reply With Quote
Old 04-11-2015, 01:51 PM   #34
John
JD367's Avatar
Rewards Points: 206
onjtrainee,
I apologize to you,if I've mislead your efforts.
Rough Rooster is correct,so I'll defer to his wisdom.
As a side note,I just went through my Kohler factory service manual,and it DOES NOT mention this system! I don't know if it's a" JD - only" thing,or what .
I guess it's time to update my manuals !
Old 04-11-2015, 02:32 PM   #35
Rewards Points: 414
No apology needed!
We are all trying to learn more and that is only possible through dialogue. Seemed to me we were having a good dialogue.
Hope all learned something here, especially onjtrainee.
I learned a long time ago to thoroughly test before purchasing parts to throw at a problem
Made an earlier post, but it disappeared in the 'etherland'.
Cheers
RR
BTW; John, what is the cart in your avatar?
JD367 (04-11-2015)
Old 04-11-2015, 03:28 PM   #36
Rewards Points: 706
AHHH.....I love a good group hug!! I feel like a wonderful moment has transpired...like what never ever happens in my normal world...people apologize, get over it...learn something..and get'r done! I'm proud to be amongst you!!
The Following User Says Thank You to onjtrainee For This Useful Post:
JD367 (04-11-2015)
Old 04-11-2015, 04:55 PM   #37
John
JD367's Avatar
Rewards Points: 206
That WAS a 1438 Toro lawn tractor.
I built a1" square-tube (1/8" wall) frame ,and used the trans axle and steering gear to make a hunting buggy. It would fit in the back of my 1985 Chevy pick up,once the roll cage and top were folded,and stowed.
I used a CV490s engine ,for power.
Unfortunately,I moved to Arkansas,2 yrs ago,so I sold it ,along with 6 other lawntractors.
Here are some pics of it,in transport mode:
Old 04-11-2015, 07:54 PM   #38
Rewards Points: 414
Looks good from here.
Built five of these.
coil replcement on JD/Kohler 12.5s oldie-pony-cart-smaller.jpg
JD367 (04-11-2015)
Old 04-11-2015, 10:30 PM   #39
John
JD367's Avatar
Rewards Points: 206
I like it!
Old 04-12-2015, 09:45 AM   #40
Rewards Points: 706
RR, I'm in Central Texas, too! When one blogger said they lived in CT..I was elated until I realized it stood for Connecticut! Maybe you are close enough that you could maybe look at this...if my buddy get's covered up. Just figured it wouldn't hurt to ask.
Old 04-12-2015, 12:27 PM   #41
Rewards Points: 414
Live north of Comanche, out in boonies. Is that close enough?
Where do you hang out?
RR
Old 04-12-2015, 12:58 PM   #42
Rewards Points: 706
RR
Not too far...Llano Cty! You ever make it to Kingsland?
Old 04-20-2015, 07:13 PM   #43
Rewards Points: 706
Must've Scared Ole Red Rooster...oh well. I went out with a socket set and took off the round housing trim piece I'm guessing will get me to the flywheel. Then there's a half inch bolt in the middle that turns when I put a socket on it. So guess there's a trick to stablizing that to get it off. Then I plan to rent a flywheel puller and go from there. Hope someone is still on board here and not out playin with their go carts.
Old 04-20-2015, 07:31 PM   #44
Rewards Points: 3,284
Now that the shroud is off read #3
SeniorSitizen is offline   Reply With Quote
Old 04-20-2015, 07:57 PM   #45
Rewards Points: 706
The shroud isn't off yet...got one stubborn side screw so I sprayed it with oil, the opposite like it broke off..erg! I still haven't been able to get the central bolt off, so not exactly in a position to test the coil yet.
First time Coil clean but on Gas Furnaces kilosos2 HVAC 19 04-26-2014 10:46 AM
Mother in law coil cleaning digitalplumber HVAC 8 08-13-2012 07:31 PM
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 04:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
