A Christmas Miracle!!! - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 12-26-2015, 07:39 AM   #1
Rewards Points: 900
A Christmas miracle!!!
OMG, I can't believe it.
Wish I could post sounds here. This was better than a present......my mower started.
Bought carb spray. Took air filter off, then figured what do I have to lose so took the housing thing that holds the air filter off. One little 1/2" metal tube fell off but I even knew it was a spacer and guessed where it fell from.
Then I sprayed the heck out of everything I could see. I was ABSOLUTELY shocked when the mower started. Its too early and wet to mow so hope I haven't jinxed myself and it starts again in a few hours.
Thank you thank you thank you.
PS
Why did mower repair shop say not to use Seafoam? Normally the first thing I would do is dump a little in gas tank.
Startingover is online now   Reply With Quote
The Following 2 Users Say Thank You to Startingover For This Useful Post:
BigJim (12-26-2015), oh'mike (12-26-2015)
Old 12-26-2015, 01:41 PM   #2
Retired Moderator
Rewards Points: 7,174
I have a chain saw like that----fires right up when I test it---
But won't start when I go to actually use it-----
Startingover (12-26-2015)
Old 12-26-2015, 02:11 PM   #3
ZTMAN's Avatar
Rewards Points: 342
Originally Posted by Startingover View Post
PS
Because if you did that they would loose a lot of carb cleaning jobs. You can pour that stuff straight into the carb and it will clean it good.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
Old 12-27-2015, 05:09 PM   #4
Rewards Points: 900
Rats!
All happy, brimming with confidence and ready to finish mowing today but no. The mower gods were frowning upon me. The mower wouldn't start. Poured a tablespoon of Seafoam in gas tank, waited a few minutes and it started right up. Whew.
The Following User Says Thank You to Startingover For This Useful Post:
oh'mike (12-27-2015)
Need help before Christmas!!! Johnyboy1975 General DIY Discussions 7 12-30-2015 10:59 PM
Christmas is coming ...need spot light on front door CitadelBlue Electrical 5 11-12-2014 07:03 AM
Last Minute Christmas Gift Suggestions user1007 Off Topic 0 12-24-2009 08:11 AM
