Changing Oil - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree1Likes
  • 1 Post By DexterII
Old 05-30-2016, 07:59 AM   #1
Rewards Points: 996
changing oil
i have a basic 3y/o TORO push. the oil can use a changing.
i am thinking just tip it over. but idk if there are precautions and/or tips to not cause problems ?
thanx
Fix'n it is offline   Reply With Quote
Old 05-30-2016, 08:24 AM   #2
Rewards Points: 202
Re: changing oil
I would disconnect the spark plug, pick it up, set on a pair of saw horses, clean the bottom of the deck with a putty knife, and expect to find a drain plug in the bottom of the engine.
listo likes this.
The Following User Says Thank You to DexterII For This Useful Post:
Fix'n it (05-30-2016)
Old 05-30-2016, 09:58 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,168
Re: changing oil
You would HOPE to find a drain plug but I have seen some newer mowers, incl. some brand names, without a drain plug which is absolutely bizarre. The owner's manual - either paper or online - might be helpful. Tipping it over to drain out the fill tube just sounds like a process that will end up in tears if, for no other reason, it pretty much requires that you drain the oil cold.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Old 05-31-2016, 08:47 PM   #4
Rewards Points: 996
Re: changing oil
i just looked. the manual, i found it under my chain saw , says to tip it.
Old 06-01-2016, 05:05 PM   #5
Usually Confused
lenaitch's Avatar
Re: changing oil
It's amazing where and how they are cutting costs these days.
Old 06-01-2016, 09:05 PM   #6
Rewards Points: 996
Re: changing oil
not only that. but they, probably correctly, assume that most people would never bother to use a drain, if it were there. so why bother. and for those that want to change the oil, tipping probably isn't a big deal.
how to build a extension shelf on the side of a changing table alpdog14 General DIY Discussions 4 09-17-2013 05:54 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Changing Roof Type Iconoclast Building & Construction 13 07-29-2011 11:15 AM
Cheap suggestions for changing look of bathroom sink countertop? mrdazzo7 General DIY Discussions 11 01-07-2011 05:43 PM
changing brake pads on a 2001 Mercury sable with ABS deck hand Automotive Repairs 10 02-18-2010 02:57 AM
