Changing Drive Belt On Mower - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 09-15-2014, 08:42 PM   #1
Rewards Points: 584
Changing drive belt on mower
Can anyone offer any pointers on how to change the drive belt on my Ariens self propelled mower?
From what I have found online, the drive pulley needs to be pulled out but it won't budge. I remember in the past when changing the blade the pulley would almost come off, but of course, now when I need it to, I can't get it to move.
Thanks for any help
Richo is offline   Reply With Quote
Old 09-16-2014, 01:24 PM   #2
A Little Of Everything
Rewards Points: 1,418
I think you've got a spring-mounted idler pulley, right? That'll have to be loosened. You'll also have to remove the blade. I think, then, you set the right rear wheel to its very lowest setting, the the left rear wheel to its highest. That should provide enough clearance to pull the belt out and under the deck.
DrHicks is offline   Reply With Quote
Old 09-17-2014, 09:59 AM   #3
Rewards Points: 584
There is a spring mounted pulley that seems to work as a guide to keep tension on the belt, if that's what an idler pulley is, but I was eventually able to get the drive pulley to come off and get the belt changed.
Hopefully the new belt makes a difference because the mower was dropping tracks of cut grass along the back wheel and perhaps it was lacking mulching power due to a 17 year old belt.
Old 09-17-2014, 10:27 AM   #4
Glad you got the belt changed!
Your tracks of grass clippings aren't because of the drive belt, however. That's more apt to be a dull blade or grass clumped up under the deck.
Back in our mowing days, we used to use graphite paint quite a bit. Wasn't a miracle worker, but it helped.
Old 09-17-2014, 10:33 AM   #5
Rewards Points: 584
Well, I've tried everything short of changing the belt. I have cleaned off the underside of the mower and used and freshly sharpened blade with no luck. Years ago I used to mulch a very long thick lawn without this problem. These days I am not taking much off and it still clumps.
I suppose I could completely clean the underside and try painting it to see if it helps.
Old 09-17-2014, 10:41 AM   #6
Hmmm... Is your blade sharp? Does it need to be replaced? Over the years, I found that I could sharpen my mower blades once, but not twice. No matter how sharp I got them, the second time around, they just did not cut well.
I suppose it's remotely possible that your engine is running at full speed any more, but I'm sure you would know that...
Old 09-17-2014, 10:50 AM   #7
Rewards Points: 584
Engine seems to be running normal speed, but the blades are just as old as the mower and have been sharpened a good 20 times each. I was wondering if it had anything to do with the blade and that could very well be the problem then.
Old 09-17-2014, 10:58 AM   #8
Wow - you got your money's worth out of that blade!
Speaking of replacing the blade(s), I'd recommend going OEM, not a cheaper after-market blade.
Old 09-17-2014, 10:59 AM   #9
Rewards Points: 584
Well, 2 of them actually I guess I am on my way to buy a new blade
Old 09-27-2014, 07:59 PM   #10
Rewards Points: 874
My Toro self propelled wasn't self propelling. I googled and found a utube video on tightening the drive belt.
For me tightening the wire by the handle helped. Wow was it ever hard to push when the self propelled function ceased to work.
Startingover is offline   Reply With Quote
Murray Lawnmower Pseck Landscaping & Lawn Care 9 05-12-2012 01:14 PM
TORO Lawn Mower vabear Landscaping & Lawn Care 1 09-01-2011 02:02 PM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
Dryer Belt KB Services Appliances 2 03-07-2008 12:35 PM
Snow blower drive belt replacement help lwhiten395 General DIY Discussions 5 01-15-2008 03:14 PM
