Can Only Experts Sharpen Blades? - Tractors & Mowers - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree68Likes
Old 03-01-2019, 06:28 PM   #31
Rewards Points: 680
Re: Can only experts sharpen blades?
Originally Posted by Startingover View Post
Flipped it over an drained oil. Now wonder if the bottle of oil I've had seversl yrs is too old to use?
It's good. Was over a million years old when they harvested it, a couple more years ain't gonna matter.
Startingover and de-nagorg like this.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-01-2019, 08:33 PM   #32
Rewards Points: 1,692
Lawn guy, thats funny. Never thought of that
On Welding:
I had an old iron bed. Too short for today’s mattresses. Took the side rails to a welder an he cut each rail in half an welded a 5” pc. in.
It’s perfect now. Only cost $20
de-nagorg likes this.
Startingover is offline   Reply With Quote
Old 03-01-2019, 10:18 PM   #33
JUSTA MEMBER
Rewards Points: 1,182
One more tip, if the bottle of oil has never been opened, it is as good as the day that it was bottled.
Shake well to disperse any settling.
But if it has been opened, there is a slight chance that any moisture in the air that was let in has formed a drop or two of water, it will be settled to the bottom, so don't shake, and pour slowly, and don't drain it all out, leave the last few drops in the bottle.
This also applies to it if you suspect that it could have had an opening, and if the seal has been broken, possibly allowing many condensings of moisture.
I have a partial case of oil bought in the 80's, that I use one now and then from.
ED
Startingover likes this.
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Startingover (03-02-2019)
Old 03-02-2019, 06:28 AM   #34
retired painter
Rewards Points: 1,504
Like the others, I've never had any issues using old oil. I've never had any 2nd thoughts using opened [but sealed back up] oil months later. I'd be more concerned about low quality oil than old oil.
mark sr is online now   Reply With Quote
Old 03-03-2019, 01:29 PM   #35
Rewards Points: 3,284
Hey Starting, keep an eye out for this ole guy. His specialty is scissors but maybe ya can charm him into doing mower blades.
SeniorSitizen is offline   Reply With Quote
Need Recommendations on a few 10", 12" saw blades clawlan Tools 9 10-10-2018 01:09 PM
Will these jigsaw blades work? harryhh Tools 8 09-01-2017 05:03 PM
Use Rockwell blades on Dremel Multimax miamicuse Tools 0 03-09-2013 12:27 PM
Which saw blades are worth sharpening? ovahimba General DIY Discussions 2 06-02-2010 06:24 PM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 05:50 AM
