Can Only Experts Sharpen Blades? - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree68Likes
Old 02-24-2019, 04:47 PM   #1
Rewards Points: 1,280
Can only experts sharpen blades?
My Honda self propelled mower has 2 blades. They're off. A neighbor with a grinding wheel offered to sharpen them but said they might vibrate if they aren't balanced.
I've known lots of neighbor's who sharpen their own blades. But that was a single blade. I don't know what to do.
Should I take them to a Mower Store?
Startingover is online now   Reply With Quote
Old 02-24-2019, 04:54 PM   #2
retired framer
Rewards Points: 1,476
Re: Can only experts sharpen blades?
Phone the dealer and ask what they do to balance blades. if anything.
Startingover likes this.
Do not use flat bottom gables with scissor trusses.
Old 02-24-2019, 05:18 PM   #3
Rewards Points: 6
It's pretty easy to balance the blades as you sharpen them with one of these:
Oregon Lawn Mower Blade Balancer 42-100 https://www.amazon.com/dp/B000VYFOJM..._iBXCCb121MBHE
If you buy a second set of blades, you can keep one set sharp while the other is mounted
Bondo, Gymschu, Msradell and 5 others like this.
w0j0 is offline   Reply With Quote
The Following User Says Thank You to w0j0 For This Useful Post:
Startingover (02-24-2019)
Old 02-24-2019, 05:23 PM   #4
JUSTA MEMBER
Rewards Points: 324
They will definitely vibrate if not balanced, and if they don't know how to balance them, then forgetabout them doing it.
It takes a little more work, but you can do it yourself with a BASTARD FILE, and elbow grease, a vise is useful, as well as a way to balance them.
ED
de-nagorg is online now   Reply With Quote
Old 02-24-2019, 06:02 PM   #5
retired framer
Old 02-24-2019, 06:10 PM   #6
Rough Rooster's Avatar
Rewards Points: 404
I sharpen blades with a 4" angle grinder (clamp them to work table) then place them on a horizontal rod, pin, or screw through hole in center and if they stay at horizontal they are balanced. If not grind a little more of heavy side (the one that hangs a little lower) and check again. When the blade will sit horizontal with no droop on end it is in balance.
Takes a little practice, but is effective. Been doing this now for 50+ years with excellent results.
RR
ps: see nealtw above. Good video and explains it well.
Rough Rooster is online now   Reply With Quote
Old 02-24-2019, 11:27 PM   #7
Rewards Points: 4,330
I've always sharpened my own blades; many different ways of making sure they're balanced.
Bondo, Startingover and lenaitch like this.
stick\shift is offline   Reply With Quote
Old 02-25-2019, 06:05 AM   #8
retired painter
Rewards Points: 826
I couldn't imagine paying someone to sharpen a lawn mower blade. If you take the same amount of metal off of each side it should stay balanced. I also hang the blade on a nail to judge if it's still balanced.
Bondo, Gymschu, Msradell and 1 others like this.
mark sr is offline   Reply With Quote
Old 02-25-2019, 07:32 AM   #9
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,418
I hang them on a nail to keep them off the floor.
Old 02-25-2019, 10:36 AM   #10
Rewards Points: 18,118
At any given time I own about 7 mowers.
I sharpen mine with a 4-1/2" right angle grinder with what's called a flap wheel.
https://www.mscdirect.com/browse/tnp...waAg8-EALw_wcB
It's far faster and better then any pedistal grinder.
I can sharpen and balance all three blades on one of my riders in about 5 min.
Of the hundreds of blades I've sharpen by far the worst ones I've seen are those double blades on a Honda mower.
There so thin you can almost bend them by hand, they wear out fast, hit one thing and there trash.
Old 02-25-2019, 10:37 AM   #11
Old 02-25-2019, 11:07 AM   #12
Rewards Points: 2,572
Allow yourself to start as a beginner. Even experts were at one time.
Old 02-25-2019, 11:25 AM   #13
Property Mgt/Maint
Rewards Points: 7,082
Don't really have anything new to add, but only to reinforce what others have already said. I clamp them in my bench vise and sharpen with the right angle grinder. If you find the grinder intimidating, then a file will work, just going to take longer. I have always just held the blade with a screw driver to check balance, but certainly nothing wrong with using a clamped nail to hold it.
Once you get the hang of it, it's much easier to keep them sharp by sharpening frequently then it is to let them go for long periods.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 02-25-2019, 01:40 PM   #14
Usually Confused
lenaitch's Avatar
Rewards Points: 242
Like Yodaman said, not much to add. I normally use a bench grinder and that plastic cone thingy. One thing to remember is that the finer the edge you put on a blade the faster it will dull - you're cutting grass, not carving meat. A word of caution if using a powered grinder - work slowly until you get comfortable with the process so you don't overheat the steel.
_________________________________________
Sic Itur at Astra
lenaitch is online now   Reply With Quote
Old 02-25-2019, 02:25 PM   #15
HenryMac's Avatar
Rewards Points: 1,002
I too use a 4" angle grinder and a Norton flap style sanding disc.
I've had one of these little balancers since the early 1980's. It's less than $5.
https://www.amazon.com/Oregon-Mower-...SIN=B000VYFOJM
HenryMac is offline   Reply With Quote
Need Recommendations on a few 10", 12" saw blades clawlan Tools 9 10-10-2018 01:09 PM
Will these jigsaw blades work? harryhh Tools 8 09-01-2017 05:03 PM
Use Rockwell blades on Dremel Multimax miamicuse Tools 0 03-09-2013 12:27 PM
Which saw blades are worth sharpening? ovahimba General DIY Discussions 2 06-02-2010 06:24 PM
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 05:50 AM
