Briggs And Stratton No Spark - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 09-17-2015, 03:40 PM   #1
Rewards Points: 22
Briggs and Stratton no spark
I have an old (70s ish) 3.0 HP Briggs and Stratton lawn mower engine that won't start. It ran a few years ago then sat in a garage for a couple of years. In all my troubleshooting the biggest problem seems to be there is no spark.
I take the spark plug out, hold it against the block and pull the cord but don't see any spark. Got a new spark plug and still no spark. If I touch the metal of the spark plug wire while pulling I can feel a jolt. Not a painful zolt, but enough that I know electricity is coming across.
Could it be there is not enough electricity coming from the coil? Why would that be? I had it apart and didn't see anything that looked wrong? What do you think I can try next?
Thanks. -Tom
retrofitz is offline   Reply With Quote
Old 09-17-2015, 03:51 PM   #2
Rewards Points: 5,348
Coils go bad, spark plugs need changing. I replaced the coil on my 20+Lawnboy because it would die after 10 minutes of running. Runs like a clock.
Ron
B. Franklin 1759
Old 09-17-2015, 03:53 PM   #3
Rewards Points: 1,502
Using the old plug, close the gap down to about 0.005" and test for spark in dim light or after dark. If there is a faint yellow spark the coil is often the culprit. Why? They just do that to us occasionally. But never say always on one of those things.
Old 09-17-2015, 05:13 PM   #4
Rewards Points: 766
70ish? It likely has points. They can corrode.
Pull the flywheel and clean them up.
AandPDan is offline   Reply With Quote
Briggs and Stratton Engine pwgsx Landscaping & Lawn Care 16 12-29-2011 05:42 AM
Briggs Stratton wont start - 12hp model: 498027 inetquestion Landscaping & Lawn Care 2 04-16-2010 06:57 PM
Briggs and Stratton generator part Jeremy Hillary Boob, PhD Electrical 3 01-10-2009 10:36 AM
5+ Year old Briggs & Stratton Won't Start Chris_In_FL Landscaping & Lawn Care 1 08-28-2008 07:41 PM
Briggs and Stratton Murray lawn mower issues golfer2b Landscaping & Lawn Care 3 08-01-2008 09:42 PM
