Bolens By MTD 22" Push Lawn Mower Model 11A-074D765 - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 06-30-2015, 11:45 AM   #1
Rewards Points: 34
Bolens by MTD 22" Push Lawn Mower Model 11A-074D765
Hi,
My Bolens lawnmower used to operate correctly..pretty much run @ a constant speed. Now it's what I call surging, I think it might have something to do with the throttle spring adjustment. I keep the air filter clean as possible. Has anyone in here had the same issue ? I've looked online for a video..etc. of how the throttle linkage is supposed to be adjusted, but so far no luck. The mower has the following Briggs & Stratton engine:
Model # 10J902
Type # 0342E1
Code # 06011954
Thanks for any help / suggestions provided.
David
Davy49 is offline   Reply With Quote
Old 06-30-2015, 04:51 PM   #2
Rewards Points: 17,912
Nothing to do with the spring.
The carburator is dirty, time to rebuild it.
Davy49 (07-01-2015)
Old 07-01-2015, 08:13 AM   #3
Rewards Points: 88
Yep, definitely think the problem is with the carburetor. You can buy a rebuild kit for the carburetor and replace the parts yourself.
thediyhubby is offline   Reply With Quote
The Following User Says Thank You to thediyhubby For This Useful Post:
Davy49 (07-01-2015)
Old 07-01-2015, 08:39 AM   #4
Rewards Points: 474
Check the price of a rebuild and a new one.I have found that some of the rebuild kits are about the same price as a new one.When you go to get the kit get the numbers off of the carburetor, this is what they will need to get you the right stuff.
BrowneBearLLC is offline   Reply With Quote
The Following User Says Thank You to BrowneBearLLC For This Useful Post:
Davy49 (07-01-2015)
Old 07-01-2015, 10:08 AM   #5
Rewards Points: 34
Hi All,
First of all..thanks for all of your replies, just to keep you all updated..yesterday before going to work I removed the the cover off the top of the engine. That exposed a lot of trash that had accumulated on top of the engine..some of which was interfering with the operation of the plastic piece that's attached to the throttle mechanism. Today I'm going to clean the carburetor..also the air filter was pretty kind of dirty, it had oil built up on it.
David
Old 07-01-2015, 10:49 AM   #6
Rewards Points: 34
Thanks to another poster in here..this is what my carburetor looks like, I just wish his image would have showed the spring's more.
David
http://blog.lawneq.com/wp-content/up...2/10/carb.jpeg
Old 07-03-2015, 07:08 AM   #7
Rewards Points: 34
Hi All,
Just to clarify what's occurring with my lawnmower, it's not surging while sitting still..it happens when moving it around,
David
Old 07-03-2015, 08:08 AM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... Rebuild the carb, it's starvin' for fuel, hence the surgin',...
TORO Lawn Mower vabear Landscaping & Lawn Care 1 09-01-2011 02:02 PM
Lawn Mower Keeps Cutting Off rmisty Landscaping & Lawn Care 3 08-25-2010 01:33 PM
Lawn Mower Question: 1405 Cub Cadet Needs Belt Put Back On flying_phoenix Automotive Repairs 5 06-17-2010 04:36 PM
My push lawn mower cuts out. Tommy Gunn Tools 2 05-05-2010 07:51 PM
lawn mower problems jamesw6777 Tools 9 08-04-2008 01:22 PM
