Best Way To Clean Push Mower Underside / Deck - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 09-05-2015, 09:48 PM   #1
Rewards Points: 351
Best Way to Clean Push Mower Underside / Deck
Hi,
I'm wondering how some of you guys clean the bottom of your mowers. I know some don't bother. But we've got a mulching blade and re-circulating plug on our Snapper Series 20 21" mower, and we like how it works. However, if the grass is even a little wet, it can bog up fast; even stopping the blade / engine. yes, we try to avoid mowing in those conditions, but sometimes we kind of really need to.
Now the instructions say you can tilt the mower on it's back wheels, and to be careful to not tilt towards the spark plug or filter. Which I've done. And had to either clean or replace the filter. They also say to drain or otherwise empty the gas tank before tilting. This is all kind of a hassle. A couple of times, I've actually lifted the whole thing up on some wood stilts to power wash the underside when it was really bad. But the thing is heavy! Short of building some crazy ramp system that would get me the big eye roll from the wife, there just has to be an easier way.
What do you all do about this? Or is it not a problem because I'm doing something else wrong.
Thanks,
Scott
Scottg is offline   Reply With Quote
Old 09-05-2015, 10:50 PM   #2
Rewards Points: 5,348
I use a 2" scrapper to clean the underside of the deck. Remove the wire from the spark plug. Put it up on saw horses and keep it level so gas or oil doesn't spill out.
Ron
B. Franklin 1759
Old 09-06-2015, 02:14 AM   #3
Rewards Points: 6,652
I just use a Pressure Washer if I want to really clean it. Otherwise I just spray it off with a jet of water from the hose, let it air dry.
Old 09-06-2015, 11:45 PM   #4
Rewards Points: 351
Yeah, I figured that there's no magic bullet. Normally, I pull the spark plug and use a scraper. Only go to the power washer if it's really bad or I have it out anyway as it's a hassle.
It's getting under it that's the problem. I guess I'll slap together some kind of easy lift system. I want it up high to make it really easy to clean.
Old 09-07-2015, 02:44 AM   #5
I just tip mine on its side. Yes a little bit of gas will come out of the carb. But it is a lot easier than trying to look up at it and get crud all over your face.
I have been doing it that way for over 36 years with no issues.
Old 09-07-2015, 04:53 AM   #6
Rewards Points: 7,054
If need be cleaned every 15 minutes park it over a sprinkler or build a 90 wand if a purchased wand isn't available.
Old 09-07-2015, 07:31 AM   #7
JUSTA MEMBER
Rewards Points: 4,190
As part of the Fall winterization process, I run mine out of gas. (never leave old gas in one as it will dry out and varnish up the jets).
And drain the oil, ( oil change yearly).
And since there is now no fluids to leak out, Tip it on it's side and pressure wash it.
let it dry, refill the oil.
Put it away for the winter, and come next year it's ready to go .
ED
de-nagorg is online now   Reply With Quote
Old 09-07-2015, 08:26 AM   #8
Rewards Points: 2,016
my toro has the garden hose fitting on the deck. i have yet to use it, so idk if it even works.
but, if it does work, putting one on a mower without one would be a good idea.
Fix'n it is online now   Reply With Quote
Old 09-07-2015, 09:43 AM   #9
dd57chevy's Avatar
Rewards Points: 3,048
It helps if you never mow when lawn is wet . PM is best !
dd57chevy is offline   Reply With Quote
Old 09-07-2015, 11:53 AM   #10
Rewards Points: 806
Its so humid and wet in summer I never have dry conditions.
I have a mulcher and know what you mean.
I tip mine on side and use a screwdriver or hand gardening claw to chip off the packed on grass. It really cakes underneath.
Startingover is online now   Reply With Quote
Old 09-07-2015, 07:52 PM   #11
chitownken's Avatar
Rewards Points: 510
Have the hose ports on my Cub Cadet. They work pretty well if you use them all the time, or if the grass is really dry. Skip the wash once when the grass id somewhat wet and you end up having to get the scraper out. They do make quite a mess when you use them. You want to put them on a mower that doesn't have one? order the port as a repair part for a mower that has them and you just need to drill a 3/4 inch hole in the deck.
chitownken is offline   Reply With Quote
Old 09-08-2015, 11:11 PM   #12
Rewards Points: 351
Yup. Trying to avoid. It's just been a super humid summer and it seems whenever we've had time to do it things have been moist. However, the pain of cleanup, etc., is maybe worth waiting a day or two.
When it's dry or bone dry, of course, zero issue. This is a good mower. And I think this is only an issue with the mulching blade and re-circulating plug. That's what very quickly stuffs up the underside. It's a hassle, but the other solution is to just take the plug off and swap the chute for the regular discharge.
I think next time I'll just try to run the tank down low enough that I can tilt on back wheels to a better degree - remove the spark plug wire - and see if I can get to it easily enough that way. Just need to totally avoid tipping towards the filter is all.
Bolens by MTD 22" Push Lawn Mower Model 11A-074D765 Davy49 Tractors & Mowers 7 07-03-2015 08:08 AM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 03:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
