Backfiring When I Turn Off - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 08-04-2015, 07:08 AM   #1
Backfiring when i turn off
Its a husqvarna mower, and backfires when i shut it down after mowing, i kill the throttle all the way b-4 turning key off. Any thoughts appreciated, thanks
Travis123f is offline   Reply With Quote
Old 08-04-2015, 08:36 AM   #2
Rewards Points: 202
Is this a new mower or a new problem with an older mower? Some engines have a fuel solenoid that shuts off the fuel flow in the carburetor, and, on some anyway, the engine manufacturer says to shut the engine off at 1/2 to 3/4 throttle, in order to avoid backfire. I know, this sounds counterintuitive, but, as I understand, the rationale is that once the key is off the engine will continue to spin under its' own momentum just long enough to evacuate the excess fuel and not dump it into the exhaust where it explodes causing the backfire. Anyway, its' an engine problem, so you need the make and model of that, and can post back here or check the engine manufacturer's site for more information. Or it may even be in the manual for the mower, but it's something that doesn't always show up there for some reason.
Old 08-04-2015, 12:21 PM   #3
I will check and try the half throttle deal, thkx
Totally stumped! Light don't turn on now? bnelson1980 Electrical 32 08-06-2014 11:37 AM
2006 Troy-bilt Zero Turn: help 97runner Landscaping & Lawn Care 13 05-05-2014 10:33 PM
dual light switches only turn off in specific positions sonofabit Electrical 3 03-14-2014 04:11 PM
Garage Lights Turn on Automatic but Also Have an Independent Switch morrisg Electrical 4 12-28-2013 11:39 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 02:46 AM
