Ariens Snowblower - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree2Likes
  • 1 Post By LawnGuyLandSparky
  • 1 Post By AandPDan
Old 02-12-2017, 07:31 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 240
Ariens Snowblower
I have an Ariens 870 snowblower.
It seems just recently when I get into a high snow area, the snowblower will slow down, I almost have to push it., like it loses power under a load.
The engine does not seem to slow, just the drive mechanism.
What adjustment to I have to make??
Is it a loose drive cable?
Barry
Barry J is offline   Reply With Quote
Old 02-12-2017, 08:45 AM   #2
Rewards Points: 1,586
Re: Ariens Snowblower
The operator's manual may suggest occasional necessary adjustments that may need to be made. If your manual got lost in the shuffle as many do, an on line manual may be available.
In the meantime enjoy some snow ice cream while searching.
Old 02-12-2017, 12:19 PM   #3
Rewards Points: 3,478
I'm thinking loose drive belt.
Bondo likes this.
LawnGuyLandSparky is offline   Reply With Quote
Old 02-12-2017, 01:44 PM   #4
Rewards Points: 766
I'd go with a belt or the friction disc is starting to wear out.
Bondo likes this.
AandPDan is offline   Reply With Quote
Old 02-12-2017, 05:03 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 2,224
Double post. Some good suggestions here and in the other post as well.
lenaitch is offline   Reply With Quote
Old 02-13-2017, 10:43 AM   #6
Rewards Points: 202
If it's anything like my Simplicity 870, as I think it might be, I remember the same condition 5 years or so ago. As I recall, there is a turnbuckle arrangement at the bottom of the rod from the handle, and I'm pretty sure that I just shortened the rod a bit at that point. That probably has a limited range, so likely not going to compensate for belts or a friction disk that are worn too far, but pretty sure that's all mine needed. I think there is a spring in the linkage just below that too, so it probably doesn't take much. Wish I could be more specific, but use the tractor a lot more often than the blower, so even at 25+ years it still looks almost new and has been very low maintenance.
Old 03-30-2017, 10:11 PM   #7
Rewards Points: 8
I have an Ariens blower and had the same issue about 2 years. I replaced the belt and it was like a brand new machine.
inzandity is offline   Reply With Quote
Old 04-14-2017, 10:00 PM   #8
Rewards Points: 462
The fact that it happens when you get into high snow suggests to me that you may need to install a baffle between the belt cover and engine mount. Repair clinic sells them for around 10 dollars plus shipping. https://www.repairclinic.com/PartDet...605600/1769721 I just installed one on my 926 but won't know if it solved the slipping problem until next winter when it snows again. Ariens recognized the problem and started installing these in their new snow throwers.
Jim F is offline   Reply With Quote
Ariens Snowblower Barry J Landscaping & Lawn Care 3 02-12-2017 04:57 PM
Ariens snowblower damaged by "eating" hose Manny32 Landscaping & Lawn Care 3 02-03-2011 08:09 AM
Ariens Snowblower Axle Wont Turn BW02916 Tools 3 11-14-2010 12:45 PM
ariens snowblower george61 Tools 1 08-18-2010 03:54 PM
ariens snowblower traction skidad Tools 2 12-17-2007 04:32 PM
