30" Craftsman Riding Mower Model No. 944.601380 - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 07-31-2016, 01:29 PM   #1
Rewards Points: 44
30" Craftsman Riding Mower Model no. 944.601380
Had post last year on my small Sears riding mower. Ended up completely overhauling it. Now the engine seems to be running irregularly - mainly when I don't have mower blade engaged. It makes an extreme whup - whup oscillation. This seems to almost disappear with the blade engaged and cutting.
ogbill is offline   Reply With Quote
Old 07-31-2016, 05:01 PM   #2
Rewards Points: 1,592
Re: 30" Craftsman Riding Mower Model no. 944.601380
Two possibilities at minimum.
1) the Lo idle circuit in the carburetor is partially plugged with debris.
2) a vacuum leak that causes the combustion chamber to get air that hasn't been through the normal passages of the fuel system. Often cause misfire and erratic running because of a greater vacuum at Lo idle than at Hi idle or at full throttle and full load.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
ogbill (08-01-2016)
Riding mower will not fire up Mikeron Landscaping & Lawn Care 2 05-15-2015 07:04 PM
Murray riding mower wont start again ezthinkr Landscaping & Lawn Care 3 05-15-2011 10:15 AM
Need Electrical HELP for riding mower RiceTruck Electrical 3 10-19-2010 03:24 PM
Murray riding mower steering gear BJF Landscaping & Lawn Care 0 09-12-2010 01:02 PM
Murray riding mower Help popcorc Landscaping & Lawn Care 0 01-26-2010 05:43 PM
