2 Stroke Oil - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Old 02-08-2015, 07:20 PM   #1
Rewards Points: 996
2 stroke oil
what is the difference between regular 2 stroke oil, and "outboard" 2 stroke oil ?
Fix'n it is offline   Reply With Quote
Old 02-08-2015, 07:41 PM   #2
Rewards Points: 1,550
The difference can be anywhere from $9.00 / Quart to $60.00 / QT.
SeniorSitizen is offline   Reply With Quote
Old 03-19-2015, 10:33 AM   #3
funflyer's Avatar
Rewards Points: 432
Without getting into technical details, air cooled two strokes need oil formulated for higher temps and protection from lean conditions where water cooled two strokes do not. The additives in oil which is rated for air cooled engines will leave deposits in a marine engine and if you use marine oil in your air cooled engine it will wear out in no time.
funflyer is offline   Reply With Quote
The Following 2 Users Say Thank You to funflyer For This Useful Post:
Ed911 (06-07-2015), Fix'n it (03-19-2015)
Lawn Mower starts for two seconds then dies guaps Landscaping & Lawn Care 36 11-10-2013 11:27 AM
T101BR up stroke blade clean cut! petros151 Carpentry 3 07-23-2012 09:14 AM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Want to Invest in Quality Tools - Basic Assortment wombosi Tools 27 01-29-2009 08:31 PM
Kawasaki FE-350 11.5hp 4 stroke engine wings3630 Landscaping & Lawn Care 2 08-05-2008 06:08 AM
