14hp Vanguard Engine. - Tractors & Mowers - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Tractors & Mowers
Like Tree2Likes
  • 2 Post By Msradell
Old 03-27-2019, 08:10 PM   #1
Rewards Points: 2
14hp vanguard engine.
Before I put my mower away last year, the pto stayed on. I just figured i would fix it this year. Well the engine appeared to be seized and i followed peoples advice on draining oil and taking spark plug out and spraying wd 40 up in the chamber. Then I changed the filter and added oil. Top of engine was able to spin by hand. Got it started and it ran for 10 mins and I left the deck off and the pto didn’t appear to be on. Then all of a sudden it goes clunk and stops. Can’t turn the top of engine by hand. All you can do is go counter clockwise a tad and then go clockwise and it stops with a clunk
Jlstoneberger is offline   Reply With Quote
Old 03-27-2019, 10:28 PM   #2
Msradell's Avatar
Rewards Points: 952
Re: 14hp vanguard engine.
It doesn't sound good for your pocketbook. The 1st thing I would do is pull the head and see if you can see anything from there. I'm guessing you will find the cylinder walls are severely damaged. If that's the case it's time for new engine.
It sounds like right now you're PTO problem is a minor one compared to the engine problem. Do you know how the PTO is engaged? Does it have an electric clutch or mechanical 1? If you get the engine running good shouldn't be too hard to troubleshoot the PTO.
Windows on Wash and lenaitch like this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 03-28-2019, 10:07 AM   #3
Rewards Points: 2
it is an electric clutch
and I am not sure what you mean by pull the head, what does that involve?
Old 03-28-2019, 07:30 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 720
I agree that it doesn't sound good and I'm not sure the engine and PTO problems are related.
I had to Google 'Vanguard' engines to find they are a line made by Briggs and Stratton. They appear to be overhead valve engines which, by the sounds of your response, suggests that you might want to find a repair shop unless you are handy and can find a repair manual.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
2002 Nissan Altima Engine Swap BigJim Automotive Repairs 106 03-25-2018 08:38 AM
What SLA battery for Snapper Rear Engine Rider mga123 Tractors & Mowers 0 06-10-2016 05:01 AM
Engine Failure! ARB Tractors & Mowers 14 08-24-2012 07:39 AM
Synthetic oil changes leonuug Automotive Repairs 29 03-18-2012 06:49 PM
Snow thrower engine problem Ultrarunner2017 Automotive Repairs 19 11-22-2011 01:16 PM
