What Substrate For Quartz Slab On Kitchen Wall - Plywood Or Hardi? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-24-2017, 12:34 PM   #1
Rewards Points: 18
What Substrate for Quartz Slab on Kitchen Wall - Plywood or Hardi?
So im going to install a 5'x4' Slab on my kitchen wall. I am just curious on what backer is best? Plywood or Cementboard? The area shouldnt see any water.
Its going to be 3cm suspended off the counter.
Thanks.
rtyler831 is offline   Reply With Quote
Old 06-24-2017, 04:18 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,292
Re: What Substrate for Quartz Slab on Kitchen Wall - Plywood or Hardi?
Is 3 cm the thickness of the slab, or the distance it will be suspended? If it it thickness, 1" is a heavy motor scooter. I would be worried more about vertical support than I would about a backer. However, I do believe I would install it on Durock. Definitely not plywood, and definitely not sheetrock. Neither have adhesion properties you will need.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Remodeling Kitchen - Wall Must Go Whyjune1st Remodeling 2 03-17-2014 11:54 PM
kitchen wall covered by sheetrock Laura774 Kitchen & Bath Remodeling 4 02-28-2012 03:23 AM
Drywall or plywood for kitchen wall robert wilson Kitchen & Bath Remodeling 1 02-20-2012 02:44 PM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
enclosing garage, non-load bearing stucco wall - do I need to cut slab & dig footing? eric559 Building & Construction 3 07-07-2010 02:41 AM
