What Is The Proper Ratio Of Portland Cement Mix For Setting Rocks In Masonry Wall? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-17-2017, 07:26 AM   #1
Rewards Points: 132
What is the proper ratio of portland cement mix for setting rocks in masonry wall?
I have an old a rock wall that needs to be patched up.
There are small voids where stone has fallen out.
My question is what is the ratio of portland cement to sand used to set the new stones in the wall?
Is the ratio different for the mix used for the mortar between the
stones on the facade of the wall?
Thanks for your help
provlima is offline   Reply With Quote
Old 11-17-2017, 08:00 AM   #2
Rewards Points: 822
Re: What is the proper ratio of portland cement mix for setting rocks in masonry wall
How old is the wall?
The new mortar should match the existing in make up as close as possible. If it is a Lime type mortar than use a lime based mortar. If it is a hard Portland type mortar the best thing to do is use a premix with a low PSI. If it is Lime based you can also get a premix to come close to the existing.
See if you can find this report on the internet ( Estimators' Reference ) Mortar Conversions.
ClarenceBauer is offline   Reply With Quote
Old 11-17-2017, 01:55 PM   #3
Rewards Points: 132
Clarence,
thanks for your reply. The wall is 30-40 years old and has some missing stones I want to replace.
What is the proper ratio of portland cement mix for setting rocks in masonry wall?-wall.jpg
Tags
mortar bedding , wall construction
Structural Wall Failing? kpm1117 Building & Construction 4 10-12-2017 07:42 AM
What is proper way to apply stone veneer to concrete wall reteng Concrete, Stone & Masonry 3 09-24-2016 03:38 AM
Finding solid wall behind tiles to mount pedestal sink! miamicuse Building & Construction 2 06-19-2016 06:23 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
