What Is The Best Approach To Fix Empty Pockets In A Concrete Slab/wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree5Likes
Old 03-19-2019, 11:44 PM   #1
Rewards Points: 14
What is the best approach to fix empty pockets in a concrete slab/wall
What is the best approach to fix the pockets seen below:
The pockets were due to the stones in place which did not allow to pass the concrete material, and later on gravity made it's way.
Options on my head:
  • Fill with liquid cement, although it won't be as tough.
  • Fill with concrete, can't guarantee it will make it into every spot of the air pocket, nor sure how to do it well without failing miserably. -Fill with liquid cement and little pieces of rock (one of the 3 components that concrete uses) so it can fill as much as possible and the pieces of rock can fill the big part.
Cutting down the affected parts are not an option.
_DRP is offline   Reply With Quote
Old 03-19-2019, 11:53 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,832
Re: What is the best approach to fix empty pockets in a concrete slab/wall
Horizontal or vertical?
I would apply some bonding agent, mix the concrete, and apply it. It wills settle out and fill pretty well if you massage it in there a bit.
Old 03-20-2019, 12:42 AM   #3
Rewards Points: 14
Horizontal connecting to the floor. A bonding agent like "Plasterbond" ? Could you give me an example?
Also from a structural point of view is it that bad? Like is it too weak or not made to last?
Thanks for your input.
Old 03-20-2019, 12:50 AM   #4
retired framer
Rewards Points: 11,906
If the steel is not SS and it is not at least 1 1/2" inside the concrete it will rust and blow the concrete apart.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 03-20-2019, 06:07 AM   #5
Rewards Points: 1,942
congrats, wash & neal,,, i'm still trying to figure out 'due to the stones in place which did not allow to pass the concrete material, and later on gravity made it's way',,, we are fast becoming a people who cannot communicate w/ea other
my bride usually uses words which have relevant meaning to her but only prompt a blank stare OR incorrect answer from me
Old 03-20-2019, 07:21 AM   #6
Retired Handyman/Painter
Johnny_inFL's Avatar
Rewards Points: 1,164
maybe the rearranged photos will help. . . . . .
if the rusting rebar is an issue, you could cover it with
cardboard, plastic, or something that will give it room
to expand and contract with the elements.
in Florida, we just slam some thick concrete mix into the
cavity, smooth it out and call it a day.
_DRP: posting your location may help a little.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
Johnny_inFL is online now   Reply With Quote
Old 03-20-2019, 09:42 AM   #7
Rewards Points: 888
There's no fixing that mess, best thing to do is tear it out and do it right
Msradell and Nealtw like this.
Canarywood1 is offline   Reply With Quote
Old 03-20-2019, 10:47 AM   #8
Rewards Points: 1,021
Bigger pics and more context would help...
huesmann is offline   Reply With Quote
Old 03-20-2019, 06:16 PM   #9
Re: What is the best approty pockets in a concrete slab/wall
NOW i see what's what,,, a mess, huh ? if it isn't, it'll do til another 1 comes along,,, tnx for the big pics
IF the op's satisfied w/structural integrity, rapid set cement will seal the holes,,, naturally CLEAN prep is of utmost importance,,, yes, wire brushing the steel & coating w/epoxy to prevent corrosion (swelling) would be beneficial
Windows on Wash likes this.
Old 03-22-2019, 08:29 AM   #10
Rewards Points: 14
Bill says 4.11MM 2.35x6 MTS 15X15 MTS
I will go to later to the store to confirm.
Old 03-22-2019, 08:31 AM   #11
Rewards Points: 14
Yes indeed, I do apologize. This is my first post so I will ensure to keep this recommendation handy for future use. My mobile is having issues transferring pics so probably tomorrow you'll have those handy along with the context.
Old 03-22-2019, 08:36 AM   #12
Rewards Points: 14
Talking
Yes an utter and horrible mess (laughing here, not to cry).
I wasn't aware of the epoxy (clearly of pretty much everything else I wasn't), maybe they already coated it, I will confirm later today.
OP would be me, NO I'm not satisfied, however there is only so much money in my budged to get the job done right but yet learn properly.
Old 03-22-2019, 08:38 AM   #13
Rewards Points: 14
Chances are I will, but before doing so, more information needs to provided to everyone that is helping so that the context may be well understood and that I do not $%^&* again....
Old 03-22-2019, 08:43 AM   #14
Rewards Points: 14
More photos to come tomorrow... I'm still putting in the balance to start over or follow your advise and call it a day. I don't like having things done half right and -- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right -- only thing is that budget MIGHT be a stopper..
Old 03-23-2019, 01:28 PM   #15
how old is this house ? i look at foundation issues & wet bsmnts every day,,, often buyers & owners clutch at seeing crks & other issues,,, IF the house's been standing for 40-50 years, it'll still be standing absent other issues' attack,,, if what i see is what it is, repairs won't break the bank
Are my concrete piers doomed to fail? Pharm80 Concrete, Stone & Masonry 6 09-11-2014 12:03 PM
Concrete and Brick Repairs spidercharm Building & Construction 6 08-26-2012 04:15 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
