Wet Basement With Stone Foundation Help - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree3Likes
Old 05-11-2017, 02:30 PM   #16
Rewards Points: 70
Re: Wet basement with stone foundation help
Yodaman,
couldn't agree more with the great advice around these parts, thanks for the input and recommendation for the better pipe.
msaramak28 is offline   Reply With Quote
Old 05-11-2017, 02:33 PM   #17
Rewards Points: 2,700
s & d is well-suited for its purpose,,, IF 1's driving over it, that's another issue & pipe class
Yodaman likes this.
Old 05-24-2017, 10:39 AM   #18
Rewards Points: 70
Here are some pictures of what i am dealing with. These were taken after a few days of solid rain. You can see the moisture on the floor, and also the two openings where water enters.
Matt
Old 05-24-2017, 10:41 AM   #19
Rewards Points: 70
Well i see it will not let me insert any photos, how many posts do i need to have prior to being able to do this?
Old 05-24-2017, 11:18 AM   #20
Property Mgt/Maint
Rewards Points: 7,384
You have more than enough posts to put up pics. Possibly doing something wrong.
http://www.diychatroom.com/f114/how-...-posts-205921/
Yodaman is online now   Reply With Quote
Old 05-24-2017, 03:54 PM   #21
IF you want dry storage, run a 60pt dehumidifier w/pump,,, cheap on eBay,,, damp always runs to dry much as cold always runs to hot - its physics + God's Will
Old 05-25-2017, 10:09 AM   #22
Rewards Points: 70
I must be doing something wrong or am blind.
I wish i could screen shot my screen, becasue there is no paper clip for attachments. Also at the bottom of the page where it shows my permissions, the little posting rules box in the bottom left corner, it states i cannot post attachments. Frustrating
Stadry, i was looking into the dehumidifiers. I found a danby 60pt for $130. Any experience with these?
Thank you both
Old 05-25-2017, 11:22 AM   #23
Property Mgt/Maint
Thank you both
At the bottom of the "quick reply" box do you have a "GO Advanced" button?
Hit that and you should see the paperclip. If not, PM administration.
Old 05-25-2017, 04:03 PM   #24
we bought a fridigaire - mid 200's - been running almost constantly for 2yrs now
'danby' i don't know
Yodaman likes this.
Old 06-22-2017, 08:54 PM   #25
Rewards Points: 394
I have a stone foundation with same info, thanks for this info because I'm really torn about how close to dig beside foundation
Originally Posted by lenaitch View Post
What I think a lot of people call an interior french drain. Just be cautious when you are digging down. Many of those old stone wall didn't have a footer as we now know it. Since they were usually built from locally found stone, often, they just laid down the largest stone as the first layer, with usually the largest of the large set in the corners. Often they are literally just that - laid on the ground. In your digging, you will want to avoid disturbing or inadvertently undermining any of them.
lpranger467 is offline   Reply With Quote
Old 06-22-2017, 09:15 PM   #26
on occasion you'll find houses with no foundation but they're built on piers w/no (or small) rooms underneath,,, lateral soil pressure causes walls to move to NO pressure side,,, our 1865 upstate house had a small storm cellar but was built on piers,,, no foundation per se - instead the walls were laid local stone about 3' deep
Old 06-22-2017, 10:04 PM   #27
Rewards Points: 394
Would you have felt safe digging beside the foundation or would you be concerned with settlement
Old 06-23-2017, 04:57 AM   #28
felt safe ? not on your life,,, i had 2 pe's do individual assessments prior to taking the job,,, owner pd 1 guy & i used my usual structural pe,,, to be fair the excavation was only open for 3d,,,& yes, i had crossed fingers for all 3
Using masonry, natural stone, or faux stone on basement walls? Minich Concrete, Stone & Masonry 1 04-09-2013 10:40 AM
Options for new basement Perry401 Building & Construction 8 02-27-2013 10:22 PM
Stone Basement Waterproofing / Foundation Footings? troyce1 Concrete, Stone & Masonry 1 02-26-2012 11:11 PM
attaching a new foundation to a stone foundation PLS Building & Construction 2 03-03-2011 11:25 PM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
