Water Nemesis - Moisture On Slab & Chimney - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Windows on Wash
Old 04-09-2019, 12:56 PM   #1
Rewards Points: 4
Water nemesis - moisture on slab & chimney
Hi all! Looking for some advice on a water issue we are having with our exterior chimney. We have a large exterior stone chimney on a 1950s ranch house which joins on one side into the brick exterior wall. We are getting moisture coming up through the slab in the room that is directly interior to the chimney area. (I assuming based upon the way the moisture moves down to the slab it is getting under the slab and wicking up?) The pictures I attached were taken the last time it rained, and this occurs every time there is rain. (Left is brick of house, right side is chimney). A large portion of the chimney is under the eaves of the roof, but the moisture "travels" along the stones much farther towards the house.
I can call the local trusted masonry company to give an estimate, but not sure if that is the contractor of choice? Or is this more a foundation/slab issue where the concrete slab meets the soil? Any suggestions on next steps would be very helpful!
Thank you!
Water nemesis - moisture on slab & chimney-chimney-issue-1.jpg   Water nemesis - moisture on slab & chimney-chimney-issue-2.jpg
seekingsun54 is offline   Reply With Quote
Old 04-09-2019, 01:37 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,604
Re: Water nemesis - moisture on slab & chimney
Need more pics from further back and the roof line as well
Bud9051 likes this.
The Following User Says Thank You to Windows on Wash For This Useful Post:
seekingsun54 (04-15-2019)
Old 04-10-2019, 06:38 PM   #3
Rewards Points: 1,842
pressure washing & applying prosoco's silicone siloxane is the usual method
Old 04-15-2019, 11:06 AM   #4
Rewards Points: 4
Sorry for the delay. Waiting for some more rain to show what it looks like wet. See attached additional pictures. Thank you!
Water nemesis - moisture on slab & chimney-chimney-issue-3.jpg   Water nemesis - moisture on slab & chimney-chimney-issue-4.jpg
Old 04-15-2019, 11:14 AM   #5
same as prev posted,,, caution: mtl will slightly darken appearance - suggest treating it all
Old 04-15-2019, 11:22 AM   #6
Yeah. Gutter pitch isn't adequate and that needs a wall/chimney kick out detail on it.
Decaying brick chimney needed to vent water heater elwood33 Building & Construction 5 05-23-2013 08:44 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
