Terracing Utilizing Two Low Retaining Walls - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By 3onthetree
Old 01-12-2019, 12:48 PM   #1
Ninarina's Avatar
Rewards Points: 4
Terracing utilizing two low retaining walls
I am planning two 40' long x 12" high stacked block retaining walls utilizing those blocks with the ledge on the back. They will be approx 15' apart with a rise of 20".
I am concerned because I don't want to jeopardize the foundation on my house as the walls will be in the fill that the house was put on.
I am in north central Florida where we don't have freezing soil issues. From what I understand, if my walls are under 4', a drainage pipe is not needed? I am only planning the walls to be 3 or 4 blocks (4" each) high with the landscape fabric encapsulating the drainage rocks behind it.
I have attached a drawing of my plan and some photos of the area that I will be building the walls on. The walls are approx 15' apart and 40' long. The rise is only 20".
Is my plan sound? Do I need the drainage pipe? Would brown river rock be acceptable for the drainage rock? (it's the least expensive option at Lowes here). How much rock will I need?
Terracing utilizing two low retaining walls-mvimg_20190109_140503957.jpg   Terracing utilizing two low retaining walls-mvimg_20190109_133122264.jpg   Terracing utilizing two low retaining walls-mvimg_20190109_133505712.jpg   Terracing utilizing two low retaining walls-mvimg_20190109_133133922.jpg   Terracing utilizing two low retaining walls-wall.jpg
Ninarina is offline   Reply With Quote
Old 01-12-2019, 01:21 PM   #2
retired framer
Rewards Points: 16,194
Re: Terracing utilizing two low retaining walls
It is the water soaked dirt behind a wall that pushes them over so drainage is important. I would want a perforated pipe in behind to take the water somewhere.
If you put gravel in 1 foot wide and 1 foot deep you need 107 cubic feet or 4 yards.
Wrap the gravel in filter cloth.
The Following User Says Thank You to Nealtw For This Useful Post:
Ninarina (01-12-2019)
Old 01-12-2019, 03:09 PM   #3
Rewards Points: 1,272
Definitely use perf pipe - do this right the first time so you don't have to do it a second time !
195795 is offline   Reply With Quote
The Following User Says Thank You to 195795 For This Useful Post:
Old 01-12-2019, 08:14 PM   #4
Hammered Thumb
Rewards Points: 1,624
Your sub-base is just as important to keep the wall level. Make sure to compact all of it.
You might want to crop out your personal info in that first pic too.
landfillwizard likes this.
3onthetree is offline   Reply With Quote
Old 01-13-2019, 10:09 AM   #5
Rewards Points: 1,861
If Nina just uses that stacked block I don't think a pipe is necessary, as long as she includes the wrapped gravel diaphragm behind the wall at the heel. The blocks will have enough perforations for the gravel to drain.
huesmann is offline   Reply With Quote
Old 01-13-2019, 10:52 AM   #6
retired framer
And you will guarantee that?
Old 01-13-2019, 04:56 PM   #7
Rewards Points: 988
Those blocks don't have any perforations in them.
Canarywood1 is offline   Reply With Quote
Old 01-16-2019, 06:15 AM   #8
They will have sufficient space between them for draining hydrostatic pressure unless she grouts them all together.
Short retaining walls - grading Kahluabomb Landscaping & Lawn Care 1 03-20-2013 08:27 PM
Retaining wall Mossiliza Building & Construction 4 07-19-2010 07:45 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
retaining walls broom Landscaping & Lawn Care 2 07-23-2009 12:14 PM
Best way to repair concrete retaining walls? ohman Landscaping & Lawn Care 2 06-25-2009 11:45 AM
