Substitute For Brick Veneer - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-21-2016, 01:31 PM   #1
jkk
Rewards Points: 335
Substitute for brick veneer
The foundation is very cracked and is being replaced. The brick veneer is coming down. After the new wall is poured, what I can use in place of the veneer? I thought about moving the new wall 'in' 4 inches but that might be impossible if I use the original footing. So keeping the original wall location will leave me with 4" wall ledge. A new deck will cover 1/2 the wall, thus covering that exposed ledge. But that still leaves 20' of wall with exposed ledge.
jkk is offline   Reply With Quote
Old 05-21-2016, 08:55 PM   #2
Rewards Points: 1,882
Re: Substitute for brick veneer
I'd never go from brick to something less than brick, in fact I'd do brick all the way up at least in front. Anyway, you could have a flashing made up that caught the first course of siding or whatever and under the sheathing, slanted down to the front of the ledge, and then bent down an inch over the ledge. Keep an angle on it to it sheds water.
ChuckF. is offline   Reply With Quote
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 06:30 PM
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 07:39 PM
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 05:57 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
