Stucco Questions After Patio Overhang Removal - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-20-2017, 04:18 PM   #16
Rewards Points: 344
Re: Stucco Questions after Patio Overhang removal
Originally Posted by ClarenceBauer View Post
If they can tell you how it will be completed and be water tight & can be done with out cutting out the 6 inches have it all in writing & signed than go for it. As for how many coats? The humidity & temperature at time of application would dictate a two or three coat system. High humidity & low temps indicate a three coat system. Low humidity & high temps a double back would work ok. No matter which system you select MAKE SURE it does not dry but hydrates in other words keep it moist while curing.
Thanks for your help, it appears I need to figure out how to make the roof overhang look better before I can have anyone do the stucco work. A licensed stucco guy said he can do it for $680 and would do 3-5 inches or more if needed but he would need to look at it. He said for some jobs he's even had to do 10 inches because the paper was in bad shape. He would do a scratch, brown, and final texture/color matched coat.
I'm trying to find a roofing person that can make the original roof overhang or make what I have on there look better in case more stucco work is needed from that modification.
Here's a picture of the overhang remnant.
sdrocker is offline   Reply With Quote
Old 02-20-2018, 10:17 PM   #17
Rewards Points: 344
Hi, I had a licensed stucco person come and start the work using a three coat approach. I saw him remove some of the old stuff including the wood and flashing and then put paper and lath. He did a scratch and brown coat from what I can see in the same day. This was about two weeks ago and we've had some warm weather and colder in the last two weeks.
Do you know if the cracks I see in the picture are normal? The person will return to do the color coat but I'm not sure if the cracks I saw today are normal or do I need to tell him before he comes back out? I'm not sure when he's coming to do the final coat but probably soon.
Thanks.
Old 02-20-2018, 10:36 PM   #18
Rewards Points: 282
I don't see any problem with those cracks you would want the scratch coat to crack rather than the finish. When the finish is applied make sure that it is moisture cured that is it should be misted to keep the humidity high do not let it dry out from the sum or wind you may need to mist 4 times a day for say 2 days or cover with damp cloth.
ClarenceBauer is offline   Reply With Quote
Old 02-21-2018, 12:09 AM   #19
Rewards Points: 344
Oh ok thanks for helping me understand! I will let the stucco guy finish it up and will ask him about me keeping it damp while it cures.
How to seal holes where stucco wall meets concrete patio cb_philadelphia Concrete, Stone & Masonry 0 05-25-2016 08:04 PM
Maximum overhang of decking boards on patio roof? garya505 Roofing/Siding 1 09-28-2015 06:37 AM
Patio with small retaining wall details.. freeclimbmtb Concrete, Stone & Masonry 0 08-08-2014 12:49 PM
Patio Cover Design Questions MrBill Building & Construction 3 06-09-2009 11:34 PM
Some 'why', not 'how', questions on stucco usage joeyboy Building & Construction 4 06-25-2007 11:22 AM
