Steps For Sidewalk Repair? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-26-2017, 10:46 AM   #1
Rewards Points: 14
Steps for sidewalk repair?
I have a sidewalk section in need of repair and I'd like to do the job myself. I've watched a few Youtube videos (this one in particular) and wanted to confirm the steps.
  1. Remove bad section and dig roughly 6" trough as well as channels on sides.
  2. Frame sides with 2x4s.
  3. Tamp down 2-3 inches of gravel and wet with hose.
  4. Mix and pour concrete mix.
  5. Level off with bar.
  6. (Roughly 1 hour later depending on weather) Edge with concrete edger.
  7. Finish with float, sponge, and/or broom.
  8. (Next day) Remove 2x4 forms.
Did I miss or misinterpret something?
Also, is there any way to separate the sections without a heavy duty circular saw, perhaps a chisel? I don't have that piece of equipment.
Lastly, is there any need to apply a sealer after a few weeks?
Thanks!
im1dermike is offline   Reply With Quote
Old 03-26-2017, 11:09 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Steps for sidewalk repair?
If you use the edger right after screeding, (using the bar? to flatten), it will knock the lumps down and create some cream which does a better finish when the edging is done later for finishing.
The tool you are missing is called a divider. They are cheap to buy. Likely under ten dollars.
Level off with bar.Screeding
First edging
Broom first, then edge
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-27-2017, 10:46 AM   #3
Rewards Points: 2,810
you can get a diamond blade for circle saws that will cut 2 1/2-3" deep then finish w/sledge hammer,,, other'n that, the 'bar' is called a 'screed',,, rest it on the forms & saw back 'n' forth to level & bring up cream
1x4's are sufficient for forms,,, sealer's not necessary
DIY Shoe Repair ddawg16 General DIY Discussions 12 02-13-2015 07:04 PM
Roof repair versus reroof and which contractor to believe? miamicuse Roofing/Siding 42 01-12-2015 10:05 AM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 09:32 PM
