Skim Coating Concrete Steps - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-10-2015, 07:44 PM   #1
From Philadelphia
Rewards Points: 291
Skim coating concrete steps
My concrete steps have been patched in a few spots in the past, and it has since looked spotty, since the new cement patches didn't quite match the old concrete. Can I skim coat the steps? I'm talking like 1/32". Is there a specific product I should use? Quikrete sand/topping mix? Quikrete mason's mix?
hellohello is offline   Reply With Quote
Old 11-11-2015, 01:29 PM   #2
Rewards Points: 2,724
cement-all in the blue box's much better impo however its white - get some gray pigment from sher wms to color it grey - that's our method
stadry is online now   Reply With Quote
The Following 2 Users Say Thank You to stadry For This Useful Post:
carpdad (11-12-2015), MTN REMODEL LLC (11-13-2015)
Old 11-11-2015, 02:37 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,096
If these steps are outside in freezing weather I would not expect it to last more than a couple of years. Freezing conditions will make it peel off.
Old 11-11-2015, 02:52 PM   #4
that's why we use cement-all OR even more expensive mix,,, w/proper prep & useage, its as permanent as the underlying conc,,, it is more expensive than the op's mention'd mtl but so what if it needs to be redone - how much is that worth ?
Old 11-11-2015, 03:08 PM   #5
Rewards Points: 1,042
Also you don't have all day with it, sets in 15 min. so you need to have a plan before you start.
Canarywood1 is offline   Reply With Quote
Old 11-12-2015, 10:14 AM   #6
Rewards Points: 492
Is the Cement-all in box different from the bag?
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Old 11-12-2015, 10:20 AM   #7
JustScrewIt's Avatar
Rewards Points: 284
By about 45 lbs
JustScrewIt is offline   Reply With Quote
The Following 2 Users Say Thank You to JustScrewIt For This Useful Post:
carpdad (11-13-2015), MTN REMODEL LLC (11-13-2015)
Old 11-13-2015, 09:14 AM   #8
Rewards Points: 492
What about sealing/stabilize the old surface? I want to do exact same with my steps but go the extra step of priming the surface. BTW, is this even necessary?
Is the box store sealer good, or is there better consumer grade solution? Eternabond primer -solvent based- was excellent, I think, but I don't know about their water based primer.
I used Cement all before, but I forget if the finish was smooth or tread-rough. Do you recommend throwing some sand on top?
Thank you in advance.
Old 11-13-2015, 03:11 PM   #9
just make certain they're in good repair prior to resurfacing,,, imhpo, not much is good from the apron/vest store if you want quality conc sealing - find some prosoco,,, you can't get a smooth finish as it contains aggregate nor would you want a smooth finish on steps
The Following User Says Thank You to stadry For This Useful Post:
carpdad (11-14-2015)
Old 11-14-2015, 08:42 AM   #10
Rewards Points: 492
Thanks for the link.
One more question. Assuming the thin top coat needs to be fairly fluid-for thin application-is there any pointers for not bringing the milk to the surface?
Old 11-14-2015, 09:00 AM   #11
this is a just-add-water mix so there's no 'milk' / 'cream' as in regular concrete,,, polymers make these materials different,,, typically they can be installed w/trowel, squeegee, or even a broom,,, i'd guess our avg thickness is less than 1/16" to no more tha- 1/8"
this is a 'skim coat' as resurfacing/decorative artisans define it,,, just prep it right - can't over-emphasize how important that step is to success
carpdad (11-15-2015)
Concrete Steps Coating marcos.cristal Concrete, Stone & Masonry 1 05-06-2015 06:12 PM
skim coating & painting moneypenny02 Painting 12 01-10-2014 03:08 AM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Dirt erosion underneath concrete front steps, fill with gravel? NewHomeDIYGuy Building & Construction 2 07-10-2012 02:44 PM
Dryer vent thru concrete steps john620 Building & Construction 5 01-31-2012 05:19 PM
