Setting Anchor Bolts In Mono-slab For Interior Load-bearing Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Bondo
Old 10-23-2019, 04:31 PM   #1
Rewards Points: 68
Setting anchor bolts in mono-slab for interior load-bearing wall
5/8" anchor bolts set at 24" OC. Pouring a mono-slab. Setting anchor bolts on the exterior is easy (either wet-set or attach them to forms). How do you set them for interior walls? If you wet set them they'll inevitably be in the wrong place. There's no form to stick them to for prepositioning? So how do you do this?
Rszimm is offline   Reply With Quote
Old 10-23-2019, 04:48 PM   #2
retired framer
Rewards Points: 1,544
Re: Setting anchor bolts in mono-slab for interior load-bearing wall
You can do all the measurements ahead of time and set up a straight line laser to place them or drill in wedge anchors later.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 10-23-2019, 05:05 PM   #3
Rewards Points: 2,600
Rockite might be a product that would be satisfactory in your application.
http://www.rockitecement.com/
Old 10-23-2019, 05:48 PM   #4
retired framer
We worked with a foundation crew that made the same mistake on ever house.
Our plans always show interior was measured from the outside of the house to the centre of the wall. I don't know how may times we had to cut off bolts and put in anchor bolts.
Old 10-23-2019, 07:16 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,790
Ayuh,....... Use 5/8" tap-cons when ya frame up the wall,......
timkoupe likes this.
Bondo is online now   Reply With Quote
Old 10-23-2019, 09:59 PM   #6
Rewards Points: 68
Thanks guys. So are the expansion bolts an acceptable replacement (per IRC) to cast j-bolts?
Old 10-23-2019, 10:25 PM   #7
retired framer
We do it all the time with a 5/8" 6" but you should maybe ask the powers that be first.
