Sealing Concrete Blocks To Minimize Moisture Wicking - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-17-2017, 07:06 PM   #1
Rewards Points: 656
Sealing concrete blocks to minimize moisture wicking
I am building a pond fountain and using #6 concrete blocks as the fountain support wall (see pic). I will be applying a stucco coat over the blocks as a final step. In dry run tests, as you can see in the pics, the blocks wick up a significant amount of water that eventually evaporates, lowering the water level of the pond.
I need to minimize this wicking effect. Do I need to apply some sort of sealer to the blocks before I apply the stucco coat?
homeimproverjoe is offline   Reply With Quote
Old 08-17-2017, 07:14 PM   #2
retired framer
Rewards Points: 6,362
Re: Sealing concrete blocks to minimize moisture wicking
It need to be water proofed below surface level, just like a house.
The Following User Says Thank You to Nealtw For This Useful Post:
homeimproverjoe (08-17-2017)
Old 08-17-2017, 07:41 PM   #3
Rewards Points: 320
Correct if the block are not waterproof from the bottom up the moisture may cause delamination of the stucco. All waterproofing will have to be a part of the stucco, stucco will not adhere to a waterproof block. You could look at some products like these Xypex additive for cement or the dry shake. STO has a product that I have use called Flexyl this is a foundation waterproofing material used in the synthetic system.
ClarenceBauer is offline   Reply With Quote
The Following User Says Thank You to ClarenceBauer For This Useful Post:
Old 08-17-2017, 07:50 PM   #4
retired framer
But this is a great picture for the people that don't believe water wicks in concrete.
No cap block available nationwide for 6 inch concrete blocks homeimproverjoe Concrete, Stone & Masonry 8 06-06-2017 10:14 PM
Concrete color change and sealing garrett1812 Concrete, Stone & Masonry 5 12-13-2016 11:44 AM
Possibility of Using Concrete Blocks for Footer of Shed Fishdamsel13 Building & Construction 16 10-24-2015 01:32 AM
Setting blocks on concrete secutanudu Building & Construction 12 09-02-2010 04:40 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
