Sealing Block After Chimney Removal. - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-23-2018, 09:39 AM   #1
Can anyone recommend the best type of contractor to seal this up after it's removed? Should someone who specializes in masonry do it? Is a general contractor sufficient? It's been disconnected from system with installation of a new furnace. About to begin finishing our basement.Sealing block after chimney removal.-img_20180223_083005877_1519396912070.jpg
DuneJeeper is offline   Reply With Quote
Old 02-23-2018, 09:42 AM   #2
Rewards Points: 1,222
Re: Sealing block after chimney removal.
You wouldn't need anybody specialized, no big deal really.
CrazyGuy is offline   Reply With Quote
Old 02-23-2018, 09:42 AM   #3
Guapo
Rewards Points: 11,950
What does it look like outside?
Guap0_ is offline   Reply With Quote
Old 02-23-2018, 09:56 AM   #4
Goes out about soil level and up. I'm sealing the top soon.
Sealing block after chimney removal.-img_20180223_084949212_1519397731998.jpg   Sealing block after chimney removal.-img_20180223_084951769_hdr_1519397767548.jpg
Old 02-23-2018, 10:54 AM   #5
Guapo
I see now. It goes into it's own stack. You can close the inside a few different ways. One is install an access door & just leave it closed. If you want something more permanent, stack a few bricks with mortar between them & skim coat it with a mortar mix.
Old 02-23-2018, 01:38 PM   #6
Rewards Points: 1,042
Foundation is made of CMU's patch with the same.
Canarywood1 is offline   Reply With Quote
Chimney Removal!!!!! Marty Gordon Concrete, Stone & Masonry 2 07-21-2016 01:26 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Please, I need help! Removing Crumbling Chimney Removal, where do i start? EyeAtDIY HVAC 8 04-25-2011 06:38 PM
glass block vent removal and installation JMuhammad General DIY Discussions 1 09-10-2009 07:29 PM
Chimney crown sealing hdhogger General DIY Discussions 1 12-10-2008 06:25 PM
