Rust Appearing Through Retaining Wall - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By jomama45
Old 02-27-2017, 05:38 PM   #1
Rewards Points: 312
rust appearing through retaining wall
was pressure washing my newly installed retaining wall, and have what appears to be rust spots on portions of the wall. If so, I am assuming from the rebar in the wall itself. Any hints or tricks on removing the stains?
KPDMinc is offline   Reply With Quote
Old 02-27-2017, 05:48 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: rust appearing through retaining wall
Muriatic acid?
With the proper safety precautions, of course.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-27-2017, 05:58 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 262
Ayuh,.... Retainin' wall is a pretty vague description to go on,....
Poured formed wall,..?? Blocks,..?? Bricks,..??
Is there proper drainage, 'n back-fill behind the wall,..??
Rust usually means water,...
Stop the water, 'n no more rust,....
For clean up, I completely agree with jlhaslip,...
Old 02-27-2017, 06:02 PM   #4
Rewards Points: 312
split faced block wall. yes, have drainage. I hadnt got my caps on and we had a long spell of rain, so, yes, water.
Old 02-27-2017, 07:02 PM   #5
Civil Engineer
Rewards Points: 5,246
Split faced block sounds like a segmental concrete block retaining wall, which would not have rebar in it. Post a picture, and try to describe in detail exactly what type of wall you have, and why you think there is rebar in the wall.
Old 02-27-2017, 07:23 PM   #6
Rewards Points: 312
pictures of the wall are in my album. and yes, there is rebar in my retaining wall, I dont think there is, I KNOW there is...
Old 02-27-2017, 10:16 PM   #7
Concrete & Masonry
Rewards Points: 464
Highly unlikely that rebar would be rusting through to the surface this quickly, especially in full grout. Eve w/o caps, the water won't pass through & corrode an encapsulated rebar that quickly. How about a close up picture?
DallasCowboys likes this.
jomama45 is offline   Reply With Quote
Old 02-28-2017, 10:13 AM   #8
Rewards Points: 312
Once the rain subsides, and the face of the wall dries again, I will take some pictures of the 'suspected' rust stainage
Replace Collapsed 4' Retaining Wall With Dirt Slope? gunner666 General DIY Discussions 4 08-07-2014 11:09 PM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 05:45 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 03:32 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
