Rough Cement - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-19-2017, 09:45 PM   #1
Rewards Points: 8
Rough cement
I want to tile an enclosed porch floor that's concrete. It was once a smooth small slab porch. We had it expanded and enclosed. When slab was expanded, the new portions were left pretty rough, as if they were gone over with a 2x4, but never smooth out. So the rough portions run the length and are about 3 x 20 long, and down one side, about 3x12. Question is, how do I smooth out rough concrete sections so,tile,lays flat? Thanks all.
Binky Tremain is offline   Reply With Quote
Old 06-19-2017, 11:02 PM   #2
Rewards Points: 2,500
Re: Rough cement
How rough is rough? Is it a broom finish or are there ridges 1/8" or higher, etc?
bob22 is offline   Reply With Quote
Old 06-20-2017, 07:50 AM   #3
Rewards Points: 8
Re: Rough cement
Broom finish would be wonderful. We are talking about multiple ridges that are at least 1/8". Its like they poured the cement into a mold, then used a 2x4 in a sawing motion to push it into place. Never went over it with a broom so smooth out ridges. Not sure it this is something I can grind out, but that would take a large unit, too much for hand held machine.
Old 06-20-2017, 08:14 AM   #4
Property Mgt/Maint
Rewards Points: 7,408
Re: Rough cement
Put up a few pictures so the tiling experts around here will have a better idea of what you are dealing with.
Yodaman is online now   Reply With Quote
Old 06-20-2017, 10:48 AM   #5
Re: Rough cement
How were you planning on adhering tiles to the concrete?
Adhesive or cement base?
Old 06-20-2017, 07:55 PM   #6
Rewards Points: 8
Re: Rough cement
Hope this works
Old 06-20-2017, 07:58 PM   #7
Rewards Points: 8
Re: Rough cement
Was planning on Ditra underpayment, thin set and stone or porcelain tiles.
Old 06-20-2017, 08:08 PM   #8
Property Mgt/Maint
Re: Rough cement
This might helpName:  rough concrete.jpg
The Following User Says Thank You to Yodaman For This Useful Post:
bob22 (06-21-2017)
Old 06-20-2017, 08:52 PM   #9
Rewards Points: 1,042
Re: Rough cement
Looks like it was struck off and they walked away from it.
Canarywood1 is offline   Reply With Quote
Old 06-21-2017, 08:01 PM   #10
Rewards Points: 2,742
Re: Rough cement
7" grinder w/12 seg turbo diamond cup wheel,,, rent the grinder that has a dust shield & buy some knee pads,,, shouldn't take over 1 hr from what i can see if you're using tile
Old 06-21-2017, 09:37 PM   #11
Rewards Points: 1,556
Re: Rough cement
Agree...but even with the dust shield I am wearing goggles and a dust mask with plenty of ventilation.....else you won't be able to see what you're doing after ten minutes!
ront02769 is offline   Reply With Quote
Old 06-21-2017, 10:01 PM   #12
Property Mgt/Maint
Keep it wet to keep the dust down
Old 06-22-2017, 04:29 AM   #13
Re: Rough cement
we don't have much luck w/hand grinders wet ,,, walk-behinds, yes,,, but that's a diff vac system,,, unlikely avg diy'er will have access to big vacs & grinders,,, 'sides, there's always a budget
not wearing masks much anymore as new vacs are doing a good job
Sloping Cement Floor guerin_matt Flooring 1 06-23-2014 12:47 PM
Basement cement floor AdamBNYC Concrete, Stone & Masonry 1 11-04-2013 04:07 PM
Cement basement floor advise AdamBNYC Flooring 3 11-04-2013 06:47 AM
question about hanging cement board in shower pillowshack Drywall & Plaster 0 01-12-2013 07:55 PM
Is Black Jack Asphalt based roofing cement okay for repairing holes in roofs? amodoko Roofing/Siding 5 11-10-2012 11:10 AM
