Room Addition To Concrete/Cinder Block House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree1Likes
  • 1 Post By Nealtw
Old 10-20-2019, 09:40 AM   #1
Rewards Points: 2
Room addition to Concrete/Cinder Block House
We just bought a 1962 cinder block house. We plan to add a master bedroom and bath on the side. We plan to use wood framing and board and batten siding on the addition. My questions are:
1. We want to join the new addition to the existing house so that there is no change in depth between the face of the block and the first batten piece. How do we do this and ensure it's a weatherproof seal?
2. Is it ok to butt the concrete trim against the cinder block?
Joe Brooks is offline   Reply With Quote
Old 10-20-2019, 11:12 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 854
Re: Room addition to Concrete/Cinder Block House
Welcome to the forums. Your profile isn't complete so we don't know where you are located. If in Florida or other non-basement locations, have you figured out the plumbing under the new slab, yet? You will need to figure on 8" walls rather than the standard 4 or 6" or you will have an indentation on either the inside or outside. Not that it would be bad for the inside.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-20-2019, 11:21 AM   #3
retired framer
Rewards Points: 962
That would not be the best for water proofing. It would be better if that first batten covered the crack between old and new.
chandler48 likes this.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 10-20-2019, 11:30 AM   #4
Rewards Points: 84
For your waterproofing sealing check out Construction Specialties. look for VF-100 joint seal. Install this between the CMU & wood framing. Than cover with your batten
ClarenceBauer is offline   Reply With Quote
Old 10-20-2019, 11:38 AM   #5
retired framer
Rewards Points: 962
How thick is that and would you attach the wood frame to the block thru it?
Old 10-20-2019, 12:00 PM   #6
Rewards Points: 84
It is a weather tight seal, it is used to seal construction & expansion joints between two types of materials. You can get it in different width & thickness.
Old 10-20-2019, 12:07 PM   #7
retired framer
Rewards Points: 962
So you could nail or screw thru it. I have not seen it before. It looks like a good product for when you are adding to an older foundation for a water seal.
Old 10-20-2019, 01:00 PM   #8
Rewards Points: 2
So the batten over the junction makes sense, but we are not going to continue the battens over the block on the original section. That would not look great. Hence my desire to butt the first batten to the corner. The addition is going to be tied to a comer so wall thickness is not a concerned. Thanks for the ideas
Old 10-20-2019, 01:16 PM   #9
retired framer
Rewards Points: 962
I am sure it can be sealed, it just that wood can move expand and contract and tends to break caulking loose. So you would want a good plan to deal with it. I guess that is why it was one of the first questions.
