Resurfacing & Extending Backyard Concrete Slab - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-18-2016, 11:30 AM   #1
Rewards Points: 2
Dr. Concrete, I have a couple quick questions regarding concrete resurfacing. Our condo association has a concrete walkway and BBQ area in the backyard. We are replacing the old furniture and grill and have decided to additionally extend the BBQ area concrete slab to the perimeter fence. The current slab is about 14' x 24' (x 6" deep) and the extension would be 14' x 8'. See attached picture. The current slab was laid ~15 years ago and was finished with a basic faux block design, likely pressed into the concrete just before its initial set. We want the final slab (current + extension) to be finished flat with a basic pulled broom finish. My questions are (1) can the current slab's non-flat blocked surface be resurfaced flat using a polymer resurfacer or will an intermediate "flattening" layer be required first, and (2) in what order would you recommend the work be done - lay new slab first then resurface as one large surface or resurface the existing slab and then lay the new slab to match? Thanks in advance for any guidance you can give.
WharfRat is offline   Reply With Quote
Old 06-18-2016, 09:34 PM   #2
Msradell's Avatar
Rewards Points: 740
Re: Resurfacing & Extending Backyard Concrete Slab
It's always hard to adhere a thin topping layer to existing concrete. Depending on what part of the country you live in it could be near impossible to get it to stay looking good over. The time. You may be better off just stamping the new section to match the old.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
jlhaslip (06-18-2016)
Concrete Slab repair for plumbing trench dshap1984 Concrete, Stone & Masonry 28 03-03-2015 08:17 PM
Pouring a concrete slab ponch37300 Concrete, Stone & Masonry 11 02-18-2015 05:33 PM
Hardwood over concrete slab alessandrot Flooring 26 06-16-2012 10:05 AM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
