Restoring 1963 Block Fireplace - Exterior - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-20-2014, 02:08 PM   #16
concretemasonry's Avatar
Rewards Points: 2,716
Those joints may not be as bad as they show on the photos. Those 2 scored block in that pattern are usually laid with 3/8"x 3/8"raked joints (squared, not tooled) and in "stack bond" as those are. My wife grew up living in a similar Levittown house outside Philly (Bucks County).
You certainly will have a lot of work cleaning out the joints and scores properly. Too bad someone totally changed the character.
Dick
concretemasonry is offline   Reply With Quote
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
jomama45 (10-20-2014), stadry (10-21-2014)
Old 10-20-2014, 04:56 PM   #17
Concrete & Masonry
Rewards Points: 384
If you want the joints to be open again, I'd highly suggest investing in a 4" angle grinder and a 1/4" thick diamond tuckpointing blade to chase the joints. If the joints are indeed raked originally, which it appears to be. If that works well, you could try a diamond cup wheel to grind some of the stubborn tile mortar off as well. Unfortunately, they're two different wheels to invest in.......
jomama45 is online now   Reply With Quote
Old 10-20-2014, 08:28 PM   #18
Rewards Points: 22
Thanks for all the great tips guys. I decided to do it the old fashion way, elbow grease, chisel and a wire brush on my grinder.
The results so far are great. Attached is a picture after 4 hours of work as you can see the bottom half is done.
Sorry the picture is sideways can't seem to get it to upload right from my phone.
I'll keep everyone posted on the progress and will most likely have more questions when I get to the sides which go into large glass panes...
gekkie96 is offline   Reply With Quote
Old 10-20-2014, 09:05 PM   #19
Msradell's Avatar
Rewards Points: 862
It's starting to look pretty good. Are you going to just leave the concrete in its natural state or are you going to stain it?
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 10-20-2014, 09:10 PM   #20
Rewards Points: 22
I'm going to paint it but not sure what color yet.
Old 10-20-2014, 09:14 PM   #21
Block will probably not stain too well because of the way they are made (high pressure, dry mix and high vibration and the density of the concrete can vary and the patterns of the cores and webs may show up a little too regular from block to block.
Dick
The Following User Says Thank You to concretemasonry For This Useful Post:
stadry (10-21-2014)
exterior foundation block TarheelTerp Painting 5 10-04-2014 07:15 AM
Best exterior latex paint for commercial block building? Marinamanager Painting 3 03-25-2013 04:07 PM
Interior finish to an exterior cinder block wall chhamilton Building & Construction 5 02-05-2009 01:01 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
