Replacing A Shower Pan - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-14-2014, 09:10 AM   #1
Rewards Points: 45
Replacing a shower pan
I have a single threshold shower with a tile shower pan that desperately needs to be replaced. The are gaping black cracks around the floor of the shower and tile around the outside of the shower door has started to fall off revealing rot behind them. To me it would seem like the pan needs to be replaced. I have a friend who lays tile and has offered to help, but in the interest of getting his help where its most needed (installing the new pan) I thought I would go ahead and remove the old one. Beyond those facts I'm at a loss. I have never done this before but it would seem like I would need to invest in an angle grinder and cut on the grout line 3 or 4 rows of tile above the floor all the way around and then hammer out the tile and backing for everything below that line. Its pretty possible I'm way off here and would welcome any suggestions.
giser3546 is offline   Reply With Quote
Old 10-15-2014, 05:35 AM   #2
Retired Moderator
Rewards Points: 7,174
Usually the walls need to be replaced also--------
If you do want to save part of the wall---the cut must be behind a tile--so pry off a row of tiles---then make the cut---that repair and the portion of the backer above the pan must be waterproofed before you new tile is installed.
stadry (10-15-2014)
Old 10-15-2014, 05:41 AM   #3
Rewards Points: 2,488
not only is mike up early he's right as usual
Old 10-15-2014, 06:15 AM   #4
Retired Moderator
It's going to rain all day----I have a lot to do---all outside-----
Old 10-15-2014, 06:34 AM   #5
Rewards Points: 144
Me too.It's rained three days straight here and still coming
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
oh'mike (10-15-2014)
Old 10-15-2014, 07:00 AM   #6
gosh, i feel guilty,,, have a 09.30 tee time + 2 quik inspections/evaluations,,, but i don't feel REAL guilty
Old 10-15-2014, 07:15 AM   #7
Rewards Points: 144
You suck
Old 10-15-2014, 10:42 AM   #8
Rewards Points: 45
I had planned on replacing the shower pan completely, just wanted to be sure taking it all the way back to the studs was what was needed. I have looked into fiberlgass shower pans, as well as the foam kits and the regular PVC shower pan liners.
Old 10-15-2014, 04:43 PM   #9
Retired Moderator
You are right--take out the pan completely---plan on replacing the drain set also---
stadry (10-16-2014)
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Removing a shower replacing with sink HuskySkull Plumbing 0 01-17-2010 12:08 PM
Need help replacing shower cartridge MrAngles Plumbing 7 03-01-2009 01:38 PM
Replacing a fiberglass shower Proulx06 Remodeling 11 06-20-2008 04:50 PM
