Removing Stains From Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By Fix'n it
  • 1 Post By Windows on Wash
Old 08-09-2020, 12:56 PM   #1
Rewards Points: 64
removing stains from concrete
Is there any hope for removing a transmission fluid stain from concrete?
I've tried a solvent like lacquer thinner, and I've tried TSP. All the fluid is gone but the stain remains.
Any way to remove it?
edfiero1 is offline   Reply With Quote
Old 08-09-2020, 04:13 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 944
Re: removing stains from concrete
Transmission fluid has a pretty good dyed tinge to it. There are some microbial bugs out there to eat fluid stains, but I don't think they are getting that deep. Is this a garage floor?
Old 08-09-2020, 05:30 PM   #3
Rewards Points: 64
Yes, Garage floor. Its about 2 years old.
Old 08-09-2020, 07:30 PM   #4
Rewards Points: 322
it will probably always be there. but, you could put down oil dry, and walk on it, grind it in, for months. did you try brake cleaner ?
Windows on Wash likes this.
Fix'n it is offline   Reply With Quote
Old 08-09-2020, 08:42 PM   #5
Rewards Points: 944
I would also look at one of the full flake epoxy coatings.
de-nagorg likes this.
Old 08-10-2020, 05:33 AM   #6
Rewards Points: 3,706
not much but try this: make a poultice of xylene & distomaceous earth,,, place on the stain & cover w/plain cardboard then plastic sheet over that,,, repeat as necessary
lacquer thinner may have caused the fluid to only soak in deeper so you'll probably need several applications IF it can even be removed
if you can't find the 'earth', try using kitty litter as a substitute
