Rebar Placement In Square Footing For Post - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree3Likes
  • 1 Post By eholmes77
  • 1 Post By Mrbuilder
  • 1 Post By stadry
Old 12-19-2018, 07:07 PM   #1
Rewards Points: 306
Rebar placement in square footing for post
Hey all. I am adding some supports in my basement/crawlspace in preparation for an attic conversion project upstairs. The engineer is having me add four posts (either PT 6x6 or permanent steel columns - my choice) with 24x24x10 footings. This will be inspected, so what does code call for in terms of rebar placement? My plan was just to use 4 18-inch pieces of 1/2-inch rebar per footing, laid out in a tic-tac-toe grid pattern held up by 4 rebar chairs where the pieces cross. That seems like it would be sufficient, but I can't figure out if there's a specific code requirement for this. Most of what I find online is for continuous footings.
I am in North Carolina. The frost depth is 12", so I am just making the footings 24x24x12 so they'll be level with grade.
Thanks for the help.
eholmes77 is offline   Reply With Quote
Old 12-19-2018, 08:10 PM   #2
retired framer
Rewards Points: 16,998
Re: Rebar placement in square footing for post
Lift the forms off the ground a little, up to 2" so the depth will still be deep enough and the bottom of the post is out of the dirt. Engineers tell us the size of the footing and the rebar specks I would do a grid of 3 or 4 each way 20" long would be 2" from the edges and 2" off the ground is right. We just hang them from the top with wires, but chairs will work.
Nealtw is offline   Reply With Quote
Old 12-19-2018, 08:22 PM   #3
Rewards Points: 306
Thanks, Neal. I think I've gotten half my advice from this site from you alone. Much appreciated.
Nealtw likes this.
Old 12-20-2018, 03:13 PM   #4
" I Can Fix It "
Mrbuilder's Avatar
Rewards Points: 434
Yes, Nealtw has an abundance of knowledge. HOG !!!!!!!! lol
just sayin'
Nealtw likes this.
just sayin
" It's ok if you're not sure, find someone who is"
Mrbuilder is offline   Reply With Quote
Old 12-25-2018, 09:15 AM   #5
Rewards Points: 3,602
here its 2 mats of #4 bar ea 20" long - 3pcs,,, 1st mat 3" off bottom & 2nd mat 3" below top,,, ea mat at 90* to ea other ( btm mat front to back & 2nd side to side ),,, ours are 2.0 x 2.0 x 1.0 high
iirc, steel has to be conc filled per fire code
landfillwizard likes this.
Tags
footings , pier , rebar
Size Rebar Needed to Reinforce Bowed Block Wall frtools Concrete, Stone & Masonry 7 06-18-2012 11:28 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 10:48 AM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-03-2008 11:37 PM
Rebar Placement in a 3x3 concrete pad. Top, bottom or middle? Deck Building & Construction 32 05-11-2008 08:44 AM
