Question For The Brick Masons - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree4Likes
  • 1 Post By ZZZZZ
  • 2 Post By Canarywood1
  • 1 Post By Nealtw
Old 08-29-2017, 01:49 PM   #1
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 844
Question for the brick masons
My house is circa 1973. The face brick and porch are all standard size brick, 8 inch long true. I went to two brick yards in my state and they said they don't make standard brick size anymore for the color brick I have, just modular size (and the brick they have in that color at modular size is a spot-on color match). I can make modular work, but I have to take every single brick off of the porch to do it. This seems a little crazy. Are their any tricks to getting modular to work when replacing standard? 3/8th's of an inch is lot to add to a mortar joint when there's only one joint present. Should I be adding pea gravel or anything to extend the mortar?
Aggie67 is offline   Reply With Quote
Old 08-29-2017, 04:03 PM   #2
ZZZZZ's Avatar
Rewards Points: 3,304
Re: Question for the brick masons
You might look around for a restoration/architectural salvage yard rather than a standard brick yard. They might have the old true 8" bricks for sale.
de-nagorg likes this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 08-29-2017, 04:07 PM   #3
Rewards Points: 1,042
Google reclaimed bricks for your area.
de-nagorg and stadry like this.
Canarywood1 is offline   Reply With Quote
Old 08-29-2017, 07:48 PM   #4
retired framer
Rewards Points: 4,618
Or steel and replace from somewhere on the house that only the nasty neighbor can see.
stadry likes this.
Old 08-29-2017, 08:38 PM   #5
Aggie67's Avatar
Rewards Points: 844
Face palm. The guy around the corner from me just took every single one of his bricks off his house to add a wrap around porch. They were all loaded into a dumpster, and they're gone.
Old 08-29-2017, 08:41 PM   #6
Aggie67's Avatar
Rewards Points: 844
This actually holds some promise. There is this little wall and a slab to the side of my front door that's hidden by bushes. I could definitely rob from that area, replace with the modular, and no one would be wiser. I believe this will ultimately be the course I take. Thanks!
Old 08-29-2017, 08:45 PM   #7
retired framer
Used building supply stores really do have a selection of brick, usually worth the time to look
Old 08-29-2017, 09:36 PM   #8
Concrete & Masonry
Rewards Points: 458
First off, it's nice to see you back Aggie, it'sbeen a while!
Second, what are you attempting to do? Replace a few random damaged brick, or add on to the porch?
jomama45 is offline   Reply With Quote
Old 08-29-2017, 11:03 PM   #9
Aggie67's Avatar
Rewards Points: 844
Good to be back, been a very busy year.
My little project involves replacing about 12 bricks.
Old 08-30-2017, 05:11 AM   #10
Rewards Points: 2,742
your absence has been noted - welcome back !
stadry is online now   Reply With Quote
Old 08-30-2017, 07:45 AM   #11
ZTMAN's Avatar
Rewards Points: 412
Saddle up and go to where they took the dumpster.
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Brick Chimney Tuck Point Question Mikhail Concrete, Stone & Masonry 3 02-04-2014 01:44 PM
question about brick patio base vipergtsxz Landscaping & Lawn Care 5 06-30-2012 03:17 PM
TV Mount onto Brick Fireplace- Brick Integrity? andrew.volkart Building & Construction 4 03-01-2011 08:21 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
Brick question [email protected] Building & Construction 1 10-18-2005 10:28 AM
