Question About Asbestos In Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree2Likes
  • 1 Post By mark sr
  • 1 Post By concretemasonry
Old 06-24-2017, 08:52 PM   #1
Rewards Points: 14
Question about asbestos in concrete
Greetings, I have a couple of questions for those who can answer them.
1. Can a poured concrete porch with steps contain asbestos?
2. How likely is it for a cinder block foundation to contain asbestos?
My house was built in 1939 and the porch is original and has been crumbling for a number of years and needs to be repaired or replaced.
My foundation walls need some repair as well. Mostly scraping off old paint and that white powder from moisture and sealing and repainting. Before works starts I need to know it I should test for asbestos for both the porch and foundation. I know mortar usually contained it. I called a couple of abatement companies and they said it wasn't likely that the porch had it. An abatement company came out and said the porch and foundation shouldn't have it but he didn't test it. I just want another opinion on the matter to be sure.
Sch84 is offline   Reply With Quote
Old 06-24-2017, 09:02 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,290
Re: Question about asbestos in concrete
Asbestos is only really dangerous if it is friable, or in dust form. I am not a concrete pro, but would not think adding asbestos to any concrete product would have been to any advantage. The main use for asbestos was heat/cold retention, and to fireproof things. Concrete doesn't burn to readily so adding it would not be beneficial.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-24-2017, 09:13 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,530
A simple google search of 'asbestos in concrete' shows that asbestos was indeed used in some concrete as a fiber to prevent cracking.
Old 06-24-2017, 09:51 PM   #4
Rewards Points: 14
Correct asbestos was used in concrete products and is still used in some concrete products around the world. In fact there are lists that show what those products are. However nothing on the web says anything about it being used in concete porches or concrete steps. It wasn't used in all concrete applications. For example there are numerous sites that show you where to look for asbestos in your home. None of them say anything about concrete porches or steps. I know it was used is in mortar a lot. There's also varying information about its use in cinder blocks. At least I think my foundation is made with cinder blocks. They look like them. I'm basically asking if anyone has ever encountered asbestos in concrete porches or stairs or cinder block foundations. Anyone who's done abatement, demolition or construction.
Old 06-25-2017, 06:38 AM   #5
retired painter
Rewards Points: 1,784
I had never heard of asbestos in concrete [but then I'm a painter] Generally if you keep it wet while removing, asbestos dust won't become airborne reducing the odds of any danger to the workers. Could your white powder be efflorescence?
Bud9051 likes this.
mark sr is online now   Reply With Quote
Old 06-25-2017, 09:12 AM   #6
concretemasonry's Avatar
Rewards Points: 2,716
I think mark has a very good point. People see something they do not understand, so they cry wolf.
The use of asbestos in concrete products is very, very rare. I have been in concrete plants in 45 countries during my 50 years as an engineer and have it used only once for a unique process and product. - Plain and simple, it is more costly, does no good and generally would be detriment for common products. There are several types of rock that contain very small amounts and those types are not used as aggregates.
Fibers have been used for some types of concrete, but they add to the cost. The common fibers are fiberglass, steel and possibly polyester, but they are costly and add significantly to the required equipment and complexity.
Dick
Bud9051 likes this.
concretemasonry is offline   Reply With Quote
Old 06-25-2017, 09:28 AM   #7
Rewards Points: 8,104
Thanks Dick,
Even if it has a small amount of asbestos the remediation would basically be the same as the repair because no one would suggest removing everything. As stated keep it wet, don't grind it and create a lot of dust and then regardless you will sleep better.
Bud
Bud9051 is offline   Reply With Quote
Old 06-25-2017, 12:38 PM   #8
The asbestos in the rock is already encapsulated in rock. Breaking down the large aggregate into smaller fractions (still gravel or coarse aggregate) does not release a significant amount of asbestos. The rock processing plant I worked at was governed by the bureau of Mines and OSHA and the employees did not have to wear any respirators unless the were working in the 90' deep pit posing a crusher. - Masks were provided for the optional use by the employees.
The rock that is used to make cement (limestone or dolomite) is a sedimentary rock and does not contain asbestos. You may see some fibers in concrete products from the glass fibers or poly fibers that are frequently used to increase the tensile/shear properties. The white powder seen on concrete in service is efflorescence is essentially Calcium Carbonate or Magnesium Carbonate the is the deposit from dissolved compounds that migrate to the surface and are left after air drying.
There is a big difference between dust and respirable asbestos.
Dick
A cottage concrete slab and a foundation question northernontario Concrete, Stone & Masonry 1 08-03-2015 06:35 PM
Question on studding my concrete wall pointer80 Building & Construction 9 05-25-2015 10:33 PM
Replacing rotten fenceposts - concrete question brendelac Concrete, Stone & Masonry 3 04-17-2015 08:07 AM
Removal of Outdoor Lampost - Concrete Question BSponz1 Concrete, Stone & Masonry 1 06-25-2012 08:27 AM
Concrete on top of Concrete question justadad Building & Construction 6 12-04-2008 02:25 PM
