Proper Water For Concrete Mix - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-29-2019, 09:30 AM   #1
Rewards Points: 6
Proper water for concrete mix
Iím installing a 170 foot long French drain in my basement. We have to cover the trench with concrete to restore the basement slab. The basement is getting finished so itís important that the replaced concrete over the trench matches up nicely and doesnít shrink noticeably so flooring works nicely.
When I add the amount of water specified to bagged concrete mixes, itís very dry and unworkable for me. I add about 15% more and itís still dry, but workable enough. When I see videos of concrete pours the mix is very wet and very soupy compared to mine. Why?
Iíve read that aside from making the mix weaker, the more water the more shrinkage. Is there a way I can create a mix that flows better but wonít shrink excessively? Are there additives? What would they be?
BTW Ė I had installed underfloor piping for a bathroom a few years back and the concrete I used to restore the slab did shrink enough that itís noticeable when dragging a shoe across the seams.
Thank you.
smarsh is offline   Reply With Quote
Old 06-29-2019, 07:17 PM   #2
Rewards Points: 1,042
Re: Proper water for concrete mix
You can use a water reducing agent or a plasticizer but be careful as a little go's a long way.
Canarywood1 is offline   Reply With Quote
