Problem Making Concrete Stairs - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree4Likes
Old 11-06-2019, 09:25 PM   #16
fred93's Avatar
Rewards Points: 76
Re: Problem making concrete stairs
Originally Posted by fred93 View Post
Good info--thanks!
I never thought of putting the stairs next to the house. I'll have to knock that around in my head for a while--thanks for the reply.
Propane tanks are in the way--nice thought though!
Nealtw likes this.
fred93 is offline   Reply With Quote
Old 11-06-2019, 10:00 PM   #17
Concrete & Masonry
Rewards Points: 404
Just a couple thoughts:
- I'd consider corbelling some 4" or 6" block behind the wall, yet still on the footing, to create some support for the back side of the steps. 4-5 points in the whole length would likely be more than adeqaute.
- Consider overhanging the steps 3-4" over the face of the painted wall. This will help out with the cantilever issue, look finished, and the block will fair better in the long run without water running down it constantly,
- I would only focus on filling the cores of the block with rebar in them, the non-rebar cores will add no strength to the wall.
- I would pour the grouted cores separate of the steps, so that the finished concrete DOES NOT lock into the block below, only the rebar bent into the concrete. Too many unpredictable re-entrant corners that will likely cause random, unsightly cracking in the steps.
jomama45 is offline   Reply With Quote
Old 11-08-2019, 12:22 PM   #18
fred93's Avatar
Rewards Points: 76
Thanks for the reply--I am understanding somewhat your suggestions but since I am not that familiar with this kind of construction can you help me with some photos/drawings of the "corbelling" that you mentioned? My main concern is how to get the corbel to attach to the existing wall that we have already built.
Old Yesterday, 09:19 AM   #19
Rewards Points: 4,590
Originally Posted by Nealtw View Post
They will have one size fits all and they don't fit all and everyone cuts the bottom off taking them off code.
You do all the math off the height 72/8= 9 but 8 is just to big for code so you redo that with 10 72/10= 7.2" and the bottom riser would be 5.7"
8" riser is the maximum code in my neck of the woods.
If your not worried about space then forget my post.
ron45 is offline   Reply With Quote
Old Yesterday, 10:22 PM   #20
fred93's Avatar
Rewards Points: 76
Hey Ron, thanks for your post.
I have had two knee replacements several years back. Unfortunately, even though I do not have pain like I had before the replacement, I do not have the range of motion that I had prior to surgery. So I would like to keep the riser around the 7-1/2" range. That number is comfortable for me. The old railroad ties that I installed years ago was okay before my surgery but now I want something with less height. (plus the ties were rotting and bug infested)
