Pouring Concrete Forms - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree15Likes
Old 06-29-2020, 10:56 AM   #1
Rewards Points: 2
Pouring concrete forms
I’m hoping to get some help in regards to making concrete forms.
I am planning to do a pour all at once as I need to rent a pump each time I get a delivery of concrete so do not want to spend a fortune.
I have a couple of questions
If I am using snap ties how many do I need per m2 of wall?
What size osb would be needed?
I plan to pour a slab and wall at the same time. Will the concrete stay in the wall form or continue to flow into the slab like water would?
Sean1975 is online now   Reply With Quote
Old 06-29-2020, 10:28 PM   #2
Msradell's Avatar
Rewards Points: 1,140
Re: Pouring concrete forms
With the type of questions you're asking you obviously don't have much experience. Your best bet would be to get someone local with experience to help you or else you're going to have a big pile of cement instead of a floor and wall.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
MTN REMODEL LLC (Yesterday)
Old 06-30-2020, 01:42 AM   #3
Rewards Points: 2
Can’t really find anyone local who has much experience with concrete formed walls tbh. No houses round here are built like that. Only the rare ICF house.
It can’t be that hard to ensure the timbers are secure with bracing.
I plan to over secure With extra thickness of timbers and more bracing to be sure but can’t find information on the normal bracing for me to ensure I over engineer the bracing
Old 06-30-2020, 03:26 AM   #4
retired framer
Rewards Points: 15,284
Wall height above slab?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-30-2020, 05:59 AM   #5
Rewards Points: 2
1.8m high
Old 06-30-2020, 06:00 AM   #6
Rewards Points: 2
It’s a pond though. So 1.2m is underground against the ground keeping it steady and 0.8m above ground
Old 06-30-2020, 06:01 AM   #7
Rewards Points: 2
1.2m underground including the slab
Old 06-30-2020, 06:02 AM   #8
Rewards Points: 2
Sorry it won’t let me edit posts.
I plan to use snap ties and several pieces of 10mm rebar too
Old 06-30-2020, 06:06 AM   #9
Rewards Points: 6,378
Originally Posted by Sean1975 View Post
It can€™t be that hard to ensure the timbers are secure with bracing.
Maybe it can be that difficult being no one is attempting it. And even if you could form it successfully it will probably crack at the 90 joint.
EDIT: EDIT:
SeniorSitizen is offline   Reply With Quote
Old 06-30-2020, 06:08 AM   #10
Rewards Points: 2
Why would it crack at the 90 degree joint?
Old 06-30-2020, 06:43 AM   #11
retired framer
I understand you want to save pump truck charges for the second pour but you are going to do a lot of work to make it happen.
We would do that in 3 pours, footing, foundation or wall and then the slab is left for the pros to do. .
If you stop filling the wall just above the top of the slab you will have some bulging out at the slab you may have to wait some time to fill the rest of the wall maybe 30 minutes or more, that will give you a cold joint and you would do he slab last with another cold joint around the edges.
We get the pump for 3 hours, and when we go over it is another 3 hours, You might go over your allotted time.
Or rebar would be 15mm with 500mm grid 2" from the outside of the wall with 2 pieces at the top and 2 pieces in the footing.
figure 7-14
Old 06-30-2020, 06:57 AM   #12
Rewards Points: 2
Is there a reason you don’t do it all in one pour though?
Old 06-30-2020, 07:03 AM   #13
retired framer
We work with engineers and geo tech engineers, they like the fill to be compacted under the slab, not sure hao you would do that.
I should have asked why you are going 1,2m below the slab?
figure 7-14
Old 06-30-2020, 07:07 AM   #14
Rewards Points: 2
No I’m not going 1.2m below slab.
My slab will be 1.2 below ground.
The slab will be 20cm thick with rebar mesh
Ontop of the 20Cm thick slab I will have a rectangular wall 20cm thick 1.8m high. With rebar in the wall. Either mesh rebar Or multiple single pcs of rebar if I use snap ties.
1m of the wall will be underground and 0.8m above ground
For a raised pond
Old 06-30-2020, 07:08 AM   #15
Rewards Points: 2
Under my slab would be solid clay
