Poured Concrete Wall Vs Block... - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree3Likes
  • 1 Post By jomama45
  • 2 Post By concretemasonry
Old 04-02-2017, 01:49 PM   #1
Poured concrete wall vs block...
For a perimeter wall foundation around 24" above grade for a 16'x 32' (2 story) cabin, is poured concrete or blocks better/easier iyo? Strength wise, are they pretty comparable? Pros/cons to each? Thanks!
stephe3063 is offline   Reply With Quote
Old 04-02-2017, 02:27 PM   #2
Rewards Points: 1,002
Re: Poured concrete wall vs block...
There are only four people left in the US who can lay block. That is the disadvantage.
cleveman is offline   Reply With Quote
Old 04-04-2017, 09:17 PM   #3
Concrete & Masonry
Rewards Points: 464
I think you might be exaggerating slightly, I could have 6-7 great blocklayers on the the job tommorow.........
landfillwizard likes this.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
concretemasonry (04-04-2017)
Old 04-04-2017, 10:15 PM   #4
concretemasonry's Avatar
Rewards Points: 2,716
Both can have equal strength. The lateral loads are mainly resisted by the reinforcement, which is goverened by the design.
For vertical loads the same applies and I have seen 20 story buildings built out of 6" thick block walls using U.S. codes. Concrete was more costly and slower.
For small or remote sites, getting a ready-mix truck into the good locationS for pouring can be a cost and problem. Block are delivered by a boom truck that can spread out the block, saving labor. For basements, a block truck can drive down a ramp into a basement or boom the block into the interior space of a basement allowing the contractor to work unimpeded by the soil dug out.
If you pour a basement and have the forms set and reinforced, it is a disaster if there is rain and the rain can't drain out and floods the forms with mud and silt that requires a lot of pumps and water to clean out before starting to pour. Mason contractors try to get a few courses up early to avoid the clean-up costs.
Have you ever seen what it costs to have a single yard of concrete delivered to finish off a pour ($100+/hr truck time) if you did not order enough extra that may be needed?
Dick
landfillwizard and stadry like this.
concretemasonry is offline   Reply With Quote
Old 04-05-2017, 08:52 AM   #5
Rewards Points: 2,834
in your situation, we'd recommend conc block on a steel-reinforced concrete footer
Paint bubbling on concrete block wall hammmer13 Painting 3 10-07-2011 08:55 PM
home-made ThermoMass concrete poured wall? jklingel Building & Construction 16 12-09-2010 09:06 PM
Dry-stack concrete block retaining wall? BRO931 Building & Construction 17 08-06-2010 08:53 AM
New window in concrete block wall swill777 Building & Construction 3 08-02-2010 02:28 PM
join poured concrete wall to CMU wall? walkman Building & Construction 1 10-01-2009 09:17 PM
