Pavers And Adjacent Cement Walk Not Even - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree5Likes
  • 2 Post By Spyder
  • 1 Post By SPS-1
  • 1 Post By SPS-1
  • 1 Post By ront02769
Old 01-02-2020, 12:18 PM   #1
Rewards Points: 68
Pavers and adjacent cement walk not even
Hello, Trying to get a feel for how best to approach my dilemma. Im trying to square up a paver foundation which butts against uneven cement walk and stairwell ( see photos).
1. My initial thought would be to somehow cut the cement back at end of walk to match up with first step of stairwell.
2. The first step is broken away slightly and dropped about and 1” or so. The hard way IMO of fixing this would be to break out the first step and I guess creat some kind of mold to re-pour first step level with end of walk.
Not sure what the easy way would be. As a DIY’er im certainly open to suggestions. thanks
owenpga is online now   Reply With Quote
Old 01-02-2020, 04:56 PM   #2
Rewards Points: 200
Re: Pavers and adjacent cement walk not even
I'm not a professional, just spitballing
1) how tall is the rise on the first step? compared to other steps? it looks short compared to others. if so, what about putting pavers on top of the first step at the level of the concrete and have that be your paver level
2) you could break out the concrete and replace with pavers.
owenpga and lenaitch like this.
Spyder is offline   Reply With Quote
The Following User Says Thank You to Spyder For This Useful Post:
owenpga (01-14-2020)
Old 01-02-2020, 05:04 PM   #3
Rewards Points: 8,914
I agree that you want to have the rise of all the steps equal, including the top step.
From here, it looks like top step is short. How much concrete would you have to pour to get the rise of the top step equal to the others ?
owenpga likes this.
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Old 01-14-2020, 09:31 AM   #4
Rewards Points: 68
Thanks for the responses. I thought they would come up in my email. I just happen to go back in to TT and saw your responses.
The difference b/t the right step and left step is less than 2”. If added paver on top step of basement steps , it would be a 10” drop The second step which wouldn’t work. My latest though would be to install the pavers and cut back 12-18” on walkway and
re-pour small section to slope down to meet pavers. I don’t want to redo the walkway at this point. Your thoughts?
Old 01-14-2020, 10:23 AM   #5
I am not picturing everything you are saying. But I think you want to try very hard to get the rise on all the steps equal. That is code because that's what it takes to make it safe.
owenpga likes this.
owenpga (Today)
Old 01-14-2020, 04:01 PM   #6
Rewards Points: 1,544
So you are thinking of installing the paver slush with the steps going down....and then doing a mini ramp up to a cut back walkway? Sounds like a plan to me. You could also cut back a bit further on the walkway and just run pavers up the slope.
owenpga likes this.
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
owenpga (Yesterday)
Unread Yesterday, 10:56 AM   #7
Rewards Points: 68
Thanks for your comment. It like your idea but it might start to look a little to segmented if i run the pavers up as the right side of the walk is actually tapered up to the railing, so I’d have to leave that section intact. I think ive found my solution and now I just need to wait for the weather to dry things up. Which might not be anytime soon this time of year. Thanks again for your help.
Unread Today, 06:59 AM   #8
Rewards Points: 68
I agree. the only way to make steps even is to lower the left side (walkway) by creating a slope down to pavers. If i bring up the top step on the right side ill have a 10” first step
which won’t work. Thanks for your response.
Unread Today, 07:39 AM   #9
I think you have the top step low. Which means that has to be brought up --- probably pouring a cap over it only way. The landing at top of stairs should be level with the top step, so that height is already defined for you too. I would cut away part of that sidewalk and slope it as required. If the difference in height is 1", removing about 18" of sidewalk should make the change in height hard to notice. Really, I would pour all that -- but pavers work too if that is your preference
Unread Today, 07:54 AM   #10
Rewards Points: 68
Like I mentioned in my last response adding more cement to the top step to basement is going to make the step more than 8 inches to the second step. I don’t want to have a nine or 10 inch first step down. over the years the foundation has shifted creating this unevenness. Like i also mentioned in previous post cutting back the existing walk and sloping it down to pavers seems like a logical solution. There is no need to bring up the other step if the solution to the problem is sloping the walkway downward. Thanks for your input.
