Patio Pour Smoothing Out Below Grade Overflow To Prep For Pond Install - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Like Tree7Likes
  • 1 Post By Windows on Wash
  • 1 Post By jlhaslip
  • 2 Post By Windows on Wash
  • 2 Post By homeimproverjoe
Old 04-13-2017, 10:57 PM   #1
Rewards Points: 640
Patio pour smoothing out below grade overflow to prep for pond install
Pics below hopefully help illustrate the issue. I will be installing a pond/water feature adjacent to my concrete poured patio. I want to use the patio edge as the left boundary of the pond. To do this, I need to make cuts to get a clean edge on the underside of the concrete so that I can get 2 rows of concrete block below it. See below...
Finished design (conceptual drawing)
Area of concern:
What would be the best tool/approach to knock down this overflow and get a clean edge on the underside of this slab? A mason chisel, an oscillating multitool with a masonry blade?
I will be digging under the lip of the patio in order to insert two rows of concrete block under this slab so that the blocks are flush with the current patio edge. Pond liner will be laid in and overlapped between the patio bottom and the top row of concrete block. The other 3 sides of the pond will be built up in similar fashion, with two rows of concrete block, then capped with 4 inch cap block. Liner will be secured by overlapping the top row of concrete block, with the 4 inch cap block resting on top of the liner.
On the patio edge, there should only be about 1/8 inch clearance between the top of the block and the poured concrete, so I need a relatively smooth underside so as not to rip the liner but to keep it held secure.
This will be a dry stack pond wall structure. No mortar involved.
homeimproverjoe is offline   Reply With Quote
Old 04-13-2017, 11:14 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,792
Re: Patio pour smoothing out below grade overflow to prep for pond install
Angle grinder with a diamond blade.
Don't beat on it as it will blow out on a crack.
homeimproverjoe likes this.
Old 04-14-2017, 02:47 AM   #3
jlhaslip's Avatar
Rewards Points: 708
14 inch gas saw would be my choice if you had one in the garage, otherwise as per above.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-14-2017, 08:45 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,918
Ayuh,.... That feature shoulda been cast into the patio,....
Old 04-17-2017, 10:19 PM   #5
Rewards Points: 640
As luck would have it, one of my neighbors just dropped off his Stihl TS 420 for me to use on this project. Same great guy let me use his DeWalt jackhammer - the spade attachment made quick work of the pond dig. The Stihl cuts through concrete like a beast. Gotta love these power tools - and helpful neighbors that don't mind sharing! Thanks Jim D!
Old 04-18-2017, 07:33 AM   #6
Yep.
Both of those are expensive pieces and the blade on that cut off saw is over $100.
Depending on how much cutting you do, might not be a bad idea to throw the neighbor some cash for the blade life.
jlhaslip and homeimproverjoe like this.
Old 04-18-2017, 09:52 AM   #7
Rewards Points: 640
Originally Posted by Windows on Wash View Post
Yep.
Good suggestion. He's definitely on the Christmas list! Crazy thing is I just met the guy a few days ago! Of all things, he's retired from the pool construction industry.
Bondo and Windows on Wash like this.
Old 04-18-2017, 11:16 AM   #8
That's a good neighbor to have.
You better take him out to dinner too and see if he has access to an excavator. Pool time after that.
Bondo likes this.
Brick patio install gone wrong Bubbagump Concrete, Stone & Masonry 22 12-28-2016 07:36 PM
Drain install in patio rss1080 Concrete, Stone & Masonry 5 04-19-2015 01:14 PM
Patio area for new construction: Pour slab and modify later, or something else? IndyGopher Concrete, Stone & Masonry 15 03-08-2014 02:05 PM
Above Grade Stone Patio repair? BSYarg Building & Construction 2 04-20-2009 07:32 PM
Help me to install a paver patio 707782 Landscaping & Lawn Care 5 09-28-2007 08:42 PM
